PNY 4GB USB 2.0 Flash Drive - Grey/Black Logo
Anonymous Posted on Feb 16, 2013
Password recovery on PNY usb flash drive4
I have a pny 16gb flash drive that was accidentally password protected and I dony recall the password
orwonka
Level 1:
New Friend:
Problem Solver:
  • Contributor 17 Answers
  • Posted on Feb 16, 2013
orwonka
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
17
Questions
6
Helped
3927
Points
33
5 Related Answers
A
Anonymous
  • Posted on May 28, 2008
SOURCE: pny usb 2.0 flash drive memory stick
windows xp doesnt recognize in drive f, when i open and prompt it to format it says disk is copy right protected. I open it and there is a bunch of foreign mumbo jumbo that i can't delete
Anonymous
  • 28 Answers
  • Posted on Jul 23, 2008
SOURCE: PNY 4 G USB DISK IS WRITE PROTECTED
Not sure what exactly is happening when you try to use the disk. Is it a used disk? Did you just purchase it? Do you get an error when trying to use it?
From the limited information, I would suggest going to the website and seeing if there is a solution from PNY: http://www2.pny.com/support/support_landing_cat.aspx?SectionID=1143 (their support page).
If it still doesn't work, post more details & I'll see if I can help.
Have a good day!
Anonymous
  • 35 Answers
  • Posted on Nov 26, 2008
SOURCE: Need Windows ME Driver for PNY USB 2.0 Flash Drive Attache
Here's what you can do,
Download the files using the these links,
http://www.usbman.com/WebDrivers/WinMe%20Sys%20Files/usbauth.sys
http://www.usbman.com/WebDrivers/WinMe%20Sys%20Files/usbhub.sys
http://www.usbman.com/WebDrivers/WinMe%20Sys%20Files/usbmphlp.pdr
http://www.usbman.com/WebDrivers/WinMe%20Sys%20Files/usbntmap.sys
http://www.usbman.com/WebDrivers/WinMe%20Sys%20Files/usbstor.sys
http://www.usbman.com/WebDrivers/WinMe%20Sys%20Files/usbui.dll
Put all these files in one folder and when windows ask for the drivers, select the option to manually serach for the drivers. And point the search to the folder where you saved these files and it should fix the problem.
If this does'nt work, please let me know.
Anonymous
  • 28 Answers
  • Posted on Jul 24, 2009
SOURCE: How to format write protected PNY pen drive???
first insert your pendrive.Now right click on my computer.Go to manage option . select disk management. From that you must select your drive letter for your pen drive.Go to Action menu near to File menu.Fromthat select all tasks and select formatting.Then again goto all tasks and select change drive letter and paths.select the drive letter and your problem is solved. thanks for asking your problem.
laikexpert
laikexpert
  • 281 Answers
  • Posted on Jan 31, 2010
SOURCE: pny 16gb attachi flash drive reccognized by my
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
How to remove write protection
How to tke write protection off a pny attahe? - Hard Drives ...
www.tomshardware.com > Forum > Storage
Tom's Hardware Guide
Sep 22, 2012 - 6 posts - ā€Ž3 authors
Hello, I have a 64 gig attache 2.0 flashdrive. ... I could not see a write protect switch in the PNY product guide, but just ... I've been trying to do this for nearly a year and today found the tool to format my 64GB PNY flash drive. ... the Link you provided and downloaded the recovery tool for my PNY USB 64 Gb ... USB Flash Drive is write protected and shows up as ...
Nov 11, 2012
Remove write protect flash memory USB - Flash Media ...
Nov 30, 2009
More results from www.tomshardware.com
how do i take off my write protection off
Is it ok if my PNY 16GB flash drive is flashing red but working fine?
You should first read the documentation to see exactly what the flashing read light means. It could mean that the drive is near full capacity. Try removing/transferring a few files to your hard drive to see if the flahing read stops. As long as it works ok, I wouldn't be too concerned.
WHY WONT MY 16GB PNY FLASHDRIVE WORK WHEN I DOWNLOAD A MOVIE ONTO IT?
Perhaps it has not been prepped, eg: not formated to use. Format it with fat32 file system using formatting software from the manufacturer. Also, make sure the movie file does not exceed 16 GB.
16gb sd card
at the command prompt type chkdsk X: /f /r where X is pen drive.If it doesn't work download the recovery tool here http://freeware-fix.blogspot.com/2013/04/usb-drive-is-unreadable.htm
Format a 16gb PNY Micro SD
Format it by using a device like a camera, the computer will not work to format this type of memory. I know this from own experience with 4 different computer in my house..
What's your problem?My PNY 16Gb sdhc mememry card keeps saying card error in my camera
There are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common cause is having the tiny slide switch on the side of the card in the wrong position. The second most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out. There are also other common causes if the above didn't help, with troubleshooting steps for this problem listed here.
Access issue to my flash drive
The drive is probably password protected by Securlock software.
Hope it helps.
7helpful
Pny 16gb attachi flash drive reccognized by my computer but says insert disk into drive when I left click it
2. Format
How do i remove the write protection on pny 8GB usb flash drive
Here is the answer from PNY.
http://www2.pny.com/support/support_single_faq_viewer.aspx?ArticleID=1415&RootSectionID=1057
Be warned, this is a low level format tool from them. What ever is on your flash drive will be erased.
I went exploring on these drives and found that when they start acting like they are write protected, it means that the drive corrupted. The low level format tool, will completely reformat that drive, and hopefully correct the problem.
They say it happens (usually) if you removed the drive from a computer, without using the safe eject USB function.
If this is a new flash drive, take it back to where you got it, and ask for a replacement.
Top PNY Electronics - Others Experts
Grand Canyon Tech
Grand Canyon Tech
Steve Sweetleaf
Steve Sweetleaf
Are you a PNY Electronics - Other Expert? Answer questions, earn points and help others
