Question about LG 37LP1D 37 in. LCD Television
Change input to tv - LG 37LP1D 37 in. LCD Television
How to source AV Input on remote
Search Results
    How do I change the input on my television? ' FAQ ' Cogeco ...
    https://www.cogeco.ca/.../how-do-i-change-the-input-on-my-tele...
    CogecoClick on the TV button near the top of the remote. Click on the video source button on the bottom left corner of the remote. Using the arrow keys to highlight/select the inputyou want. Some televisions may require pressing the source button multiple times to change the inputs.
    Understanding Inputs - Harmony Support - MyHarmony
    https://support.myharmony.com/.../understanding-different-input-changi...
    Televisions, AV receivers, soundbars and other home electronic devices switch ...Devices with toggle (or cycle) inputs have a single button on their remote that ... In the below example, you would press the Source button to bring up a list of ...
    Changing AV input on TV using Sky remote ' AVForums
    www.avforums.com > ... > Satellite TV, Sky TV & FreeSat
    Changing AV input on TV using Sky remote. Discussion in 'Satellite TV, Sky TV ...VSX-924 LG simplink changing AV source to TV. Posted By djrobmac In AV ...
    Selecting the DVD, VCR, Game Console, HDTV, Camera, or ...
Feb 08, 2016 | Venturer KLV39150 15" Under Cabinet LCD TV...
How do i change the input
The 27" TV uses the same instructions as the 20", and I found the manual for you at the link below. Answering your question directly, here is the section of the instructions about changing input:
Changing the TV's Input Normally, your TV displays the signal coming through the antenna terminal. However, if you've connected another component to your TV(such as a VCR & DVD) using the Video/Audio input,you will want to be able to view the signal from the component.To do this, you will need to switch from the ' TV ' input to the 'AV1-AV3, CVI' Input, as follows. 1 With the TV on, press the MENU button twice, then " Set-Up " menu will appear. 2 Use the WCHV buttons to select " Input ". 3 Press the CVOLB buttons to change the input source from ' TV ' to 'AV1, AV2, AV3, CVI'. 4 Wait 20 seconds, or press DISPLAY button or MENU button to return to normal TV viewing. * CVI means the Component Video Input (Y/ PB/ PR) from the DVD player etc.* Users can also select these input modes with the TV/AV button or the INPUT button on theremote controller. * On the AV1 mode , if you connect the S-VHS jack to your TV, "AV1" is changed to "S-VIDEO".
The link to the manual is below.
Jun 01, 2014 | Daewoo DTQ-27U4SC 27" TV
I cant get any of my inputs to change my kids hooked up the Xbox and now none of the inputs work for cable or DVD its just a blue screen with a no signal can anyone help me tonight please
Kindly check first if the batteries of your TV remote ( medium to change input ) are fresh. After that please check again the button on your TV remote for INPUT, SOURCE, or TV/VIDEO and it should give you input lists.
May 12, 2014 | Televison & Video
How to change input on philips tv
Hello
If the tV has a "Menu" button at tis fron panel, you can press it and surf through, come to input selector window, and can change the input to TV. If there is no Menu button on its front panel, there is no other way to change the inputs without its remote control.
Feb 27, 2012 | Philips Televison & Video
How do i get the TV to play satellite? it just says weak signal when I turn the tv on. JVC RM-C18G
It has to be on the right channel. If you are supposed to be on channel 3, 61, 73, 113 (ask the satellite company which one you should be on) then you'll have to change the channel. If you are not supposed to be on a channel you have to find out which input you're supposed to be on (video 1, video 2, video 3, av 1, av 2, av 3, hdmi 1, hdmi 2, input 1, input 2, input 3 for example).
Jul 19, 2011 | Televison & Video
I cant keep my tv turned on after i pushed the rgb button by mistake it keeps on displaying no signal and then it goes off
Turn on the TV again. You need to change the input from RGB back to cable or HDMI or Component or whatever input you have a source for. If you don't know which one, look at the back of the TV and the wires you've got plugged into it.
If it's 1 round coaxial cable, change the input to Cable.
If it's three wires (red, white, and yellow) change the input to A/V.
If it's 5 multicolored wires, change the input to Component.
If it's an HDMI cable, change input to HDMI.
If you cannot change the input before the TV turns itself off, try unplugging the TV from the wall socket for about 10 seconds, and then plugging it back in. If its still on RGB, you're going to have to either find a way to get faster at switching inputs, or find an RGB cable and something to connect it to your TV. This is a last resort however.
Jun 09, 2011 | Televison & Video
Orion TVD2710. Lost remote, can't change signal input
I would suggest you try to find a universal remote that has an "input" or "source" button and program that one to your tv. By pressing the "source" or "input" button, it will change the input to the tv. I hope this helps! -Der Strom
Apr 06, 2010 | Orion STV2763 27" TV
Mintex 37 inch wide screen. remote is working however cannot change channel, input source or volum. only turns tv off. The buttone on tv doesnot work connot change input source or volume
Check if the remote is in TV position, that is, because most of the remote controllers have the feature that you can program them for use with another devices. Make shure that one button that says "TV" in pressed and released once before you try to change any function on the TV.
Jun 27, 2008 | Mintek DTV-373-D 37 in. LCD HDTV
No longer can change inputs on tv
mine did the same and i have been told that it is the mother board
Nov 21, 2006 | iLO 2600 Television
LG 37LP1D 37 in. LCD Television Logo
43 people viewed this question
Ekse
RONALD CARTER JR
