GE GSS20IEPWW / GSS20IEPCC Side by Side Refrigerator Logo
Posted on Feb 10, 2009
Ice in ice maker starts to melt then refreezes into large clump
I have a GE side by side refrigerator/freezer. When ice maker is turned on, the ice is made then starts to melt, then re-freezes causing a huge
ice clump.
Also, food in freezer has ice crystals all over them and ice droplets
are all over inside of freezer walls.
Eveleen Korbos
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Jan 21, 2019
Eveleen Korbos
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1008
Points
The heating fan which turns on and off for defrosting is eathier stuck and wont start to defrost fast enough its a 35 part if you can do it your self when this happens its the defrost elment is going out
5 Related Answers
Anonymous
  • 833 Answers
  • Posted on Dec 18, 2007
SOURCE: Gss25wgsd bb model number
Mick...there may be any number of reasons for this. First, check for a bad door gasket. It must be clean and fit snugly around the unit. Use a piece of typing paper about 2 inches wide to pull through. It should pull with some resistance anywhere you try. If it is gappy, humidity can leak in.
Next, make sure the condenser coils are clean. Third, how cold is your freezer? Is should be about 5 degrees or so if it is kept closed for about 6 hours or more.
Is the ice maker clean and not overflowing? Many units can be removed and cleaned out.
You may have other issues...start with these.
aborcass
Ron Coons
  • 2651 Answers
  • Posted on Feb 24, 2008
SOURCE: Clumps of ice cubes in back of ice bucket
sounds like your just might not be using enough ice and they are defrosting and clumping together.figure your pulling ice from front of bucket the the backs hardly get used espescially in winter your not using as much ice. or ice maker is slightly over flilling water and dripping over rear of unit
A
Anonymous
  • Posted on Aug 10, 2008
SOURCE: Ice cubes melting then refreezing in clumps
check the flap door to see if it is slightly open letting warm air in
ginko
Ginko
  • 19396 Answers
  • Posted on Nov 29, 2008
SOURCE: Clump of ice in bucket
That means that the evaporator fan system that releases the the ice cubes is not working as it should.
The evaporator fan and heating system must be checked, and fan, or solenoid, or element must be replaced.
Use the number listed on the owner manual if you want to call a technician.
Enter model number on this website to find schematics and replacement parts.
Anonymous
  • 1606 Answers
  • Posted on Sep 27, 2009
SOURCE: Ice melts, then refreezes. Rubber Is HOT
Pull the refrig out , and remove the back panel . Is the fan that cools the compressor working ? Is the coil roll clean ? If the fan is not working , then the problem is probably the main control board . Behind the 8"X10" panel , above the compressor area . Remove the cover , and look for a burnt resistor , just to be safe . If this fan does not work , then the coils and the refrigerant line running between the doors , will get very hot .
The ice being produced is large clumps that melt and refreeze and stop the auger from turning. I have to use a blowdryer to melt the ice just to remove the bin. Any suggestions?
Can you provide a model number of the refrigerator? Is the water filling too high in the ice maker? Are the top of the ice cubes connected together before the ice drops into the ice bin?
APPLIANCE 911
3answers
1helpful
Sometimes ice melts in ice maker. Water drips down and refreezes.
There is a heater built into the ice maker bottom to help release ice cubes from the machine. Under normal conditions the heater only come on when the ice maker starts to run and then jambs against the frozen cubes. When it stalls and jambs against the frozen ice cubes, the heater comes on to melt the cubes enough. I think you have a defective ice maker and the heater is coming on to much or at the wrong time, Since your temps go back to normal with the ice maker turned off, I am almost sure thats your problem.
Ge Profile ice maker not working
you either have a bad water valve, which it is sticking open or B. the ice maker is not shutting the valve off.
Ice cubes made by ice maker become large fused chunks over time.
Ice cubes will deteriorate over time if not used. They shrink due to defrosting of the freezer and will become stale.
Once the ice bin is full, turn the ice maker off until you use the cubes and or dump the cubes every 3 or 4 days and start over.
2answers
GE side by side with ice and water in door
This is a problem with my GE side by side also. It only happens occassionally and there doesn't seem to be any fix. I've had GE repair service here more than once. It seems that the insulation in the door is insufficient to keep the water line from freezing up. Small wonder GE is part of this awful financial mess.
Top Refrigerators Experts
vince
Johnny 1000
