The VGA driver for your system is listed below:
Vga Driver
Please also be sure to install the Chipset beforehand:
Chipset Driver
SOURCE: soundcard, modem driver and video controller (vga compatible)
you can check the manufacture website for the drivers
SOURCE: video driver for acer travelmate 2350 series
From reading the other comment I think you have the updated driver if the is the case reboot your computer and it may update (it may not be able to update while it is using it) then after rebooting go to add remove hardware and update driver if the computer wants a location go to Window/inf and it should find the right driver from there you may ge one of three messages I have the most updated driver or do you want to replace it or do you want to keep or replace this driver from here I would try any of them you can always go back to how it was before See if this works and get back to me if it does not
SOURCE: 1. Driver Description:Video Controller (VGA
If you log onto the manufacturers web
site, a list of drivers that you require will become readilly
available. Just follow the links. Hope this helps to get you up and
running again.
