Unit displays "Check Cable" whenever attempting to scan. Yes, I have installed the CD provided with the unit and all of the software. As well, the cables themselves are properlya dn securely connected.Unit displays "Check Cable" whenever attempting to scan. Yes, I have installed the CD provided with the unit and all of the software. As well, the cables themselves are properlya dn securely connected.
You can't post conmments that contain an email address.
Number one! have you installed the cd that came with the machine? you probaly did not install paperport which is the scanning program, may be you do not have the usb cable hooked up between the printer and the cpu?????????good luck ! brother sr tech
scanning relates to twin drivers and interfaces, assuming the software being used is from the same manufacturer their should not be an issue with it if you reinstalled the twin drivers and software.
You just install scan software in your computer. scan option will visible on your desktop then click on your scan option then ...you can scan your document.......
Look to the left side of the flatbed glass for a thin strip of glass by itself. When you scan from the glass, the document stays put and the sensor moves across the document. When you scan from the feeder, the sensor stays in that glass strip and the document moves across the sensor. See what I mean? I would check the small feeder glass for dirt or scratches from staples or other flotsam. Also not a bad idea to blow out the feeder path with some compressed air to ensure the documents is handled smoothly. Hope this helps!
Before buying a product verify with Web that product is compitible with XP. If no then check with seller. Else if u have already bought try installing with all good accessories (cable connection) etc. All the best.
