Washers normally don't have much grease in them at all....the
transmission is full of oil....which on GE washers often gets dumped
onto the floor.Remove power, tilt the washer back and check on/around/near the large
center pulley under the tranny....often the belt and pulley throw the
oil around inside the cabinet.
Some of the oils they use are a synthetic oil....acts a little diff
than some other oils....sometimes if water gets into the tranny the oil
can change foamy or black due to the moisture.
The
first thing to check when your GE washer is not agitating, is the belt.
Let me tell you how to check the belt & the clutch with out having
to take the washer apart.
The belt: Set the timer in the spin cycle and pull the timer knob to turn the washer on.
If
the washer drains the water and then spins the way that it should, this
tells you that the motor, belt & clutch are not the reason why your
washer won't agitate.
A broken belt could be the reason your washer is not agitating or spinning.
The agitator: After making sure that the belt, motor & clutch are working ok, lets check the agitator.
The
agitator uses a plastic agitator coupler that is couple to the
transmission shaft by using splines cut in the coupler and on the
transmission shaft.
Too much
usage or overloading the washer too many times will wear the agitator
coupler splines. With out the splines the coupler could not be coupled
to the transmission shaft and that could be the cause why your washer is
not agitating.
The clutch: A
bad clutch could also be the reason the washer won't agitate or spin.
Usually when the clutch is bad the washer will be noisy, like when you
have bad brakes on your car.
The transmission: The
transmission could be the reason your washer is not agitating. A common
problem with the transmission is oil leaking right on top of the motor
pulley and the belt.
As you
can see, there could be different reasons why your GE washer is not
agitating. You just need to keep checking each part until you find the
problem and replace the part responsible.
Thanks a lot for helping me with this. I don't want to seem annoying with the same thing, but I would like you to tell me the origin of this "clink" noise when the machine runs in washing mode. Thanks again
