Washing Machines Logo
Posted on Feb 10, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
ERROR F11 (Whirlpool Duet GHW9300)
Says F11 Error what does it mean?
Anonymous
Level 2:
Scholar:
  • Expert 105 Answers
  • Posted on Feb 10, 2009
Anonymous
Expert
Level 2:
Scholar:
Answers
105
Questions
0
Helped
46190
Points
236
Hi there this is as it reads for your fault code F11
Serial Communication Error
Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
  • Check Wire Harness connectors to the MCU, the motor, and Central Control Unit (CCU)
  • Check the Drive system for any worn or failed components
  • Check MCU
  • Check CCU
  • Check Motor
WHAT MEANS ERROR CODE FOR MY DRYER MACHINE F11?
if its a Kenmore model then this message says that the button control board has lost sight of the main control board , but its been my experience that this maybe able to be reset and it may never come back or it will not reset and the control board will need replaced (50/50)
cycling power may reset this
Jan 30, 2016 • Dryers
What does f23 error mean?
Display shows an error code - Front-load washer ' Whirlpool ...
https://www.whirlpool.com/...error-code...w...
Whirlpool Home AppliancesCheck the following answers for error-code related issues you can correct: ... Duet SportTM washer - F01, F11, F23, F24, F27, F28, F29, F30, F31, and F33.
What does error code f23 flashing mean on a Whirlpool ...
Whirlpool duet washer error code F11
The F11 code means that the CCU (central control board) and MCU (motor control board) aren't communicating properly. This can be caused by poor contacts between the wires in the wiring harness and one of the boards. Someone reported a simple fix of carefully adding solder to thicken the contact area on the board where the wiring harness plugs onto the board.
First unplug the washer. You need to check the wiring for any broken conductors. Try wiggling the wiring harness on both sides to see if that helps the connection stabilize. If wiggling works, then the solder solution may work. Warning: make sure to keep the new layer of solder directly on top of the previous contacts. If the solder spreads sideways, you can short the unit. Otherwise, the solution is to replace the CCU. If that doesn't solve the error, Whirlpool recommends replacing the MCU.
If you add the model number for your washer, I may be able to point you to the parts list. I hope this helps.
We have a whirlpool duet washer that flashes F11 and will not start, I made sure the door shuts tight and also tightened the plastic latch that was loose, still not responding, please advise what you think...
The F11 error code means that the motor control unit& the central control unit aren't communicating with each other
It could be a loose wire connection between the MCU/CCU or either one could be defective
Gene
Hi we have a Whirlpool duet Model ghw9300 and i have already replaced the circuit board once about a year ago it was flashing f6 code,now it is doing it again and when it shuts down it drain all the water...
F6 : Drive Motor Tachometer Error
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin the door will be unlocked after 3 minutes.
Potential Causes
Check wire harness connections between the Drive Motor/Tachometer and the Motor ControlUnit (MCU), and between the MCU and the Central Control Unit (CCU)
Check the Drive Motor • Check the MCU • Check the Wire Harness
2helpful
I am getting an F20 error message or SUD. I have
http://www.wikihow.com/Fix-a-Whirlpool-Duet-Washer-F-20-Problem
1helpful
Error code F11
Not sure what machine you have?
F11 Error Code for Whirlpool Duet & Duet HT :
F11 is Serial Communication Error, communication between the central control and the motor control unit cannot be sent correctly.
Check all connectors at the motor control and the Main control, check the motor, check drive system for any worn or failed components.
This is the only F11 Error code I could find for a washer.
Jan 13, 2010 • Dryers
1helpful
F11
these error codes are not specific FDL can mean door latch failure .it can also mean the ccu board has failed also F11 can mean mean anything from motor to motor control board to ccu board to wiring harness connecting ccu to mcu to motor. if you do not know how to diagnose with out error code you may end up buying wrong part. sometimes doorlatch is not problem central control board CCU is
1helpful
Whirlpool Duet Washer GHW9150PWO Have F11 and DL errors. Have replaced the door lock 2 x and still have same error messages.
Well du is a door lock error but it can also mean an error with communication to the main control board or ccu. f11 is also a communication error in either the ccu or the mcu ( motor control board)......easiest thing to try is to unplug all your connections to the ccu and plug them back in and try it again.....sometimes a wire harness just may be loose....if that dosent work I would look at replacing the ccu ( central control unit )
2answers
Duet Washer not working after a year
F11 means that the motherboard is not talking to the computer that contols the drive motor Fdl is a door lock failure code - i had this exact issue with several and the motherboard resolved it, unfortunately it retails at $324.99
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
