I have a kitchenaid Superba gas oven. Model YKGRT507FW0. Oven does not light. Broil and range top is fine. Activate oven and display is normal showing LO but does not heat up. Appear glow igniter is not coming on ? Any thoughts ? I have also read that the self cleaning function can damage the front circuit board ?
Thanks
Todd
SOURCE: Oven/Broiler Igniters for KitchenAid range KGST307
Guy, your missing some letters at the end of the model but I compared 4 different gas slide in's starting with KGST307 and the part numbers are bake ignitor 9751123 and broil 9751784. Catriver..post back
SOURCE: Kitchenaid Superba Gas Range
It appeared to be something to do with the plenum and cleaning - repair man came - cleansed and it was okay. MK
SOURCE: Finding a replacement night light bulb for kitchenaid superba
KitchenAid KESC307
The bulb inside the oven is 40 watts appliance
You did not indicate which bulb you need but you can go to
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=251681
and click on the diagrams in the left-hand side to locate the bulb you need.
SOURCE: Kitchenaid Superba Gas Oven Touch Pad not working
We have a gas kitchenaid KGST307HBL9 and the touch pad is blank, but we discovered that you can still touch the buttons and it will work. (example touch bake; temperature; start). It will beep when the target temperature is reached.
Just so we don't forget and leave the oven on, we turn the oven light on as our signal. A little work, but not wanting to "fork" out the money at this time to repair.
Also, if you are handy RepairClinic.com has many items and can also answer question. We've used them for several of our appliance repairs.
SOURCE: Kitchenaid Superba Gas Range - Oven temperature problem
The problem is: the temp seems to be 'stuck' at 260 and will not allow any higher settings.
Calling KitchenAid proved to be unuseful. The manual did not have this item in the troubleshooting pages. Resetting the power does not help.
The SOLUTION:
There is really no problem besides that the temp display setting has been somehow set to be celsius (metric system) rather than farhenheit (english system). Changing this setting somehow can be easily touched off without knowing, thus the "I didn't do anything and yesterday it was working fine..." comment from family members.
The FIX:
Reset the temp display back to farhenheit (F). This is done by opening the oven door, then hold down the 'Broil' button until you hear a beep from the control panel. The same method may be used to change from Farhenheit back to Celsius.
Prevention:
I speculate the inavertent change of the temp setting is done while cleaning the flat control panel. So the best thing to do is to always 'LOCK' the control panel when cleaning the controls. This is done by holding down the keypad "3/lock" for a few seconds until the display shows LOCK.
(The solution was already posted when I arrived at this page. I just organized it a bit by adding some details and a preventative comment. Many thanks to those who posted earlier, solving my issue as well. I hope my writing presents a clearer and quicker read to the next person)
