The battery is no longer taking a charge properly and needs to be replaced.
Right on RANDY!
New battery shipped from California ~ under $20 on eBay... Bring your Frankenstein back to life!
Anthony
1500mAh Battery For Motorola CP200 CP200D CP200XLS PR400 Portable Radius...
SOURCE: Radius CP200 is in monitor mode I think and i
Your programmable buttons can be programmed to a number of options. Typically the first button is programmed to monitor and sticky monitor. If this button has been held in a long press you can clear the setting by holding it in another long press to shut it off, or by simply shutting the radio off and turning it back on.
Your second programmable button could be set for an number of features, but like the above description, simply pressing it again or shutting off the radio will turn the feature off.
When you refer to Monitor Mode, we assume your are indicating the radio is operating open squelch, with no private line code. This is when you can hear ALL transmissions on your frequency. If this does not describe the problem you are having please repost another question.
SOURCE: problem charging
If you are referring to a flashing yellow light on the charging base, this is an error code. Either the 1) battery is bad, 2) not making good contact in the charger, or 3) very very low on charge. The solution for this set of problems is as follows: 1) have the company you purchased them from replace them, 2) clean your contacts with a pencil eraser, 3) leave the battery on the charger with the yellow light flashing for an hour or two. If the battery is just very low on a charge, it will come back to life and the light will change to be constant. If the battery is bad or shorted out, the light will continue to flash and you will need to get with the vendor you purchased the batteries from.
Other things which come to mind are compatibility issues such as you are using a different battery chemistry than you had before. NiCd batteries can charge on either of the two chargers available for the P110 (slow rate or fast rate). However, NiMH and Li-Ion batteries require a fast rate charger.
If you are referring to a yellow blinking light on the radio while it is in the charger. You need to shut your radio off. Radios should always be turned off when charging. If the radio is left on you will never have a full charge. Also, if you inadvertently press the PTT while the radio is turned on, while on a charger, you can cause damage to the radio.
FYI: There is no light to show "out of range" on the radio, unless you are possibly using a trunking or repeater system. A blinking light on your radio indicates the radio is turned on and/or there is traffic on your frequency. Your charger base light can be red, yellow or green. This indicates the charge cycle status. Flashing most always means some type of error.
Best regards
Not True at all!
Motorola CP150/CP200/CP200XLS/PR400
If LED is blinking Yellow....
This is a Smart Charger so there is factors
If you talk on your radio allot and battery gets hot from talking on the radio and then you place the Radio/Battery on Charger then.....
LED Indicator will blink Yellow because
1. Battery is Hot and unsafe to Charge, The battery will blink Yellow and stop when battery cools down then it will go to solid Red Light.
2. Battery is Completely dead, waiting to charge or building Blocks to start charging process.
3. Battery is DE- Charging!
Instead of fully charging, Its UN-Charging AKA
Draining your battery on Purpose. Motorola Smart Chargers will Drain battery once so often to preserve Battery life.
4: issue with connection or making contact, or Issue with Charger dock/Adapter... RARE or near impossible. If you are experiencing Blinking Yellow indicator then... 90 percent of time battery is Draining 100% then will Start Charging once fully drained. This is a Special Unexplained feature than Motorola Does to help you preserve you battery life.
Don't listen to these guys... I work for Motorola!
Blinking Red= Dead battery, No longer Chargeable
