No, you should use same amount of toothpaste like regular toothbrush. You can use electric toothbrush without toothpaste but it is not that effective, I would suggest proper amount of toothpaste which is required for teeth to be cleaned. Electric toothbrush keep your teeth clean and away from gum problems.
Top 5 Best Electric ToothBrush Reviews
No, you should put the same amount of toothpaste on all types of toothbrushes. You should put enough so you can clean your teeth well.
SOURCE: Do electric toothbrushes require a different amount of toothpaste compared than manual toothbrushes?
The main advantage of manual toothbrushes is the cost. They are much
cheaper than electric toothbrushes. Whereas an electric toothbrush can cost you
$50-$100, manual toothbrushes can be bought for just a few bucks. Another
advantage is that manual toothbrushes come in different sizes and colors, so
there's a larger variety to choose from.
In order to keep your toothbrush clean and germ free, you should do the
following:
Rinse the toothbrush thoroughly after every use and
make sure there's no toothpaste left.
When not in use, make sure that the toothbrush is
away from other toothbrush or any other tools that could have germs on them.
• Make sure that the head of the toothbrush is not covered because then it would get warmer, which will promote bacteria growth.
Electric toothbrushes are an excellent tool to keep your teeth clean and
healthy. They offer many advantages:
They allow you to remove plaque more efficiently and
quicker than manual toothbrushes.
You don't need to brush hard in order to get good
results. This means that you are much less likely to injure your gums.
People who suffer from physical conditions like
arthritis find electric toothbrushes as a great replacement to manual
toothbrushes because they are easier to grip and you don't need to use as much
physical power to get your teeth cleaned (the powered brushes do the cleaning).
• It is more fun to brush with electric toothbrushes compared to manual toothbrushes, especially for children.
You need an extra soft bristled manual toothbrush, toothpaste you like which must contain fluoride and a mouth rinse.
