After about 8 hours of use shut down twice at the end went to use on another job shut down after 2 minutes and time and time again after a short amount of time getting great pressure but starts to surge when it starts to shut down. some times hard to pull after it shut down until it cools down.
SOURCE: Dewalt 3800 PSI operates great
When you pull to start squeeze the water hose tigger until start.
SOURCE: Hi, I have a Dewalt pressure
There are two common issues that will cause what you are describing. What you need to do is run the machine until it dies as you are describing. Then pull the spark plug and check for spark. If you do not have spark you have a failing stater. It is very common for this problem to only show itself after the machine warms up. If you find that you do still have spark try removing the gas cap and restarting. It is also common for a vacuum lock to occur due to the seal on the gas tank cap. In most cases one of these will be your issue. If not feel free to contact me at 800.247.8103 and I will help you to troubleshoot the issue further.
Sincerely,
Aron Kerr
Landa Northwest
www.landanw.com
