LG WM-2277HW Front Load Washer Logo
Sandy b Posted on Feb 10, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Parts diagram for lg dlex7177rm - LG WM-2277HW Front Load Washer
Paul
Level 2:
Sergeant:
  • Expert 381 Answers
  • Posted on Feb 15, 2013
Paul
Expert
Level 2:
Sergeant:
Answers
381
Questions
0
Helped
146109
Points
960
Www.searspartsdirect.com
use it as a reference
LG DLEX7177RM Not drying clothes
Either of these:
1. Air flow is blocked
2. Heating element is not working totally or not at all.
Check airflow for strong flow. If not. Unblock
check airflow for heating. If hot then heating element is working. If not hot, check heating element issue,ie, reset hi temp thermistor, check other thermistors, check heating element for continuity.
Report back what you find.
Oct 10, 2018 • LG Dryers
LG Dryer low heat doesn't work
It may be as simple as checking your lint filter.
If you use fabric softeners sheets, they tend to clog the lint filter holes. Washing it with soap and water will restore it back to normal and will allow the circulation that the dryer needs to properly dry your clothes.
How do you take apart the LG DLEX7177 Dryer to fix it?
This link should take you to the repair clinic. Their videos are great. This is how I learned to get into mine. Good luck.
http://www.repairclinic.com/LG-Dryer-Model-DLEX7177RM-ID-882536-Parts
LG Model DLEX7177RM makes a rumbling noise upon start up like a bad bearing or gear drive sound. Noise is cyclic at dryer spin speed. Dryer is only a couple years old. Are there any recalls, warranty...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker
Jan 02, 2011 • LG Dryers
My lg DLEX7177RM dryer turns on but,when u push the start button,it dosent work,nothing at all.I have changed the main sercuit board and nothing?
Check the light switch to make sure it's working and check the belt to see if it's broken.
Good luck
Oct 01, 2010 • Dryers
Where can i get a parts diagram for a LG 14225FD Mike
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
This tip also tells you how to find a parts diagram...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Lg dryer wont heat up DLEX7177RM how do I reset the thermostat
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Top LG Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
