Copier stays on please wait after resumig one job
There are two possible solution, the first is that the Drum Potential Sensor is damaged and need to be damaged, the second is that may the NV-RAM is damaged and need to be replaced. This two possible problems need to be solved by a experienced technician. If this question is posted by a user, than the only thing you may check is do the PCU Harness is connected good. That harness is located under the touch screen, when you will open the front door, than putt the toner bottle in position for replacement. right under the touch screen behind the toner bottle you will see two harness re-connect them and see do the problem will be solved if is not than are the two other possible solution i mentioned in the start of the answer. good luck.
I fixed it, it was difficult to put the harness in but I did persevere
