Wont spin
According to the alarm code E58 is usually a washing machine with inverter and means problem with inverter board or motor or wiring between inverter-motor.
Could be:
E58 - Inverter is drawing too much current (> 4.5A).
Abnormal motor operation (overload).
Motor-inverter wiring faulty.
Motor faulty.
Inverter board faulty.
E57 - Inverter is drawing too much current (>15A)
Motor faulty.
Dado
SOURCE: front load washer
Unless pump motor is dead I'm 99% sure that either filter, pump and/or drain pipe are clogged.
SOURCE: Kenmore HE2 front load washer. All cycle lights flashing plus spin and clothes clean lights on.
I'm sure this is probably too late, but hopefully it will help some else. I just had the same problem. First, unplug the power. Then take the lower front panel off and grabbed a bucket. Place the bucket under the large "plug" on your right. This is the drain. Slowly unscrew the drain plug, Hold your nose as it will probably smell. Allow the water and such to drain into the bucket. When you see the blob of wet lint drop into the bucket you will know why the machine refused to work. Make sure you clean the drain plug and screw it back in tightly. Put the lower panel back on and reconnect the power. I hope this resolves your issue.
SOURCE: error codes for Electrolux front load washer EWF 1087
E40 error is door interlock faulty, could be the lock or it could be the pcb u have to test them.
SOURCE: my amana front load washer wont spin and is
Hi
Thanks for using FixYa. From what I understand the error code ND means “No
Drain issue”. You’ll need to check for any restriction in pump assembly. It can
also be due to a restricted drain hose or loose wire at pump. If after cleaning
the drain hose the issue is not resolved then it means the pump has gone bad
and unfortunately needs to be replaced. Please do rate the solution if the issue is
resolved or post a comment for further assistance.
Thanks
Rylee
SOURCE: washer codes F01/F33, have cleaned the pump and
The F33 error code indicates a pump drive system error. If the pump ohms out correctly & the harness is secure I recommend replacing the CCU (central control unit).
Please see the following image provided for instructions.
http://media.fotki.com/1_p,stwwfrggtqfbrbbxgtqsskgwtqkq,vi/wgtbwqwssxsbwkbdtfwxrbfbddwwf/1/1303472/5961857/image9159087223444281043img-or.jpg
Remember to disconnect power to the washer before attempting access.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!
Hello jamespeattie - Does the washer making a humming noise? If so, either the drain hose may be kinked or the drain in the house is clogged. Once you have confirmed and cleaned the hose and if issue continues contact a professional to move forward accurately. The unit may possibly have a faulty pump or control board.
Problems
with a washing machine not spinning or not draining are often inter
related..
If you are having a problem with your top load
washer then check out this tip...
Washing
Machine
does not Pump or Spin
If you are having problems with your
front load washing machine then checkout this tip...
Front
Load Washing
machine not draining and or not spinning
heatman101
Check your wire harness at the wire tie attachment point on the motor. The factory has a tendency to cinch those ties too tightly. They can cut your wires over time leading to intermittent connections and therefore power surges leading to error messages!
I found out the hard way after replacing the control board and the motor...
