SOURCE: toro powerlite ccr model#38175
seems to me you have water or dirt in you carb pull the carb off take the bowl off clean it real good try to do so over a bowl or bucket to see the fuel that comes out to determine if its water or just dirt
SOURCE: i have a toro ccr 3650 snowblower the electric start just grinds
This problem has been solved! I took the covers off the machine, removed the starter and eventually replaced the drive. Apparently the drive parts were put on back ordered and took about 4 weeks to get the drive set. One thing I suggest if anyone does this is to look at the fly wheel to insure it's in good working order. The dealer I worked with said often that is chewed up (the teeth on the fly wheel) and leads to a bigger headache. Fortunately mine was just fine. The machine now works likes like new as I put in a new spark plug as well!
SOURCE: i have a toro ccr 2450 snowblower. i bought it
No if your belt is shredding there is something rubbing on the belt. Check the idler/tightner pulley see if it spins freely. Check make sure nothing but the pulleys are touching the belt when it is engaged.
Sam
Testimonial: "Thank you for the quick response."
SOURCE: Where can I get a manual for a toro CCR-3650
go to www.toro.com and should be able print it there.
