SOURCE: fridge making loud snapping noises
we have much the same problem except ours was going on for some hours at a time and then off for short periods. contacted Comet engineer who says its the compressor and will cost almost as much as a new machine to fix it. we are disgusted as its only just over a year old and has been repaired twice already. we would also add that both
the fridge and freezer are now completely out of action and have been all over the Easter period which has caused us much inconvenience. we will take this matter further if no satisfaction is gained from Comet.
SOURCE: admiral refrigerator -shelf removal
You just "pop out" the blue clips. Then pull the shelf out and relocate it to your desired position. Lastly, replace the blue clip to the top of the hole where you placed your shelf.
SOURCE: ADMIRAL 60ADIBSL
You should be able to remove the grille on the bottom front of the frige. Then look underneath for the drip pan. They are made to be pulled straight out for occasional cleaning. Check online instructions for your particular model. Good luck!
SOURCE: GC2224gek admiral freezer keeps defrosting
I believe your defrost control board is defective part number 0165748 You can visit my site below and enter the part number or the model number GC2224GEK in the search feature. We also offer free help, Thanks, Sea Breeze
http://servicepartstec.blogspot.com/
Testimonial: "Thank you for your response. It was the circuit board that was faulty just over a year old. It was replaced just before I saw your email. "
SOURCE: Admiral/Maytag fridge/freezer gc2227cdfb
No the water supply to ice and water does not have to be hooked up for it to work.
