Start>All Programs>Accessories>System Tools>System Information
Why do you need to know the manufacturer of these devices?
Error code 28 means the drivers are missing. A hard reboot could fix it. A virus scan could fix it (use malwarebytes free version).
Your bigger problem is Windows Vista: one of the worst operating systems ever put to market. I would suggest backing up all of your data, then do a clean install of Windows 7.
Uninstall the chipset driver and reinstall it, this error is related to incomplete or interrupted chipset driver installation. Make sure that all the drivers are installed correctly.
For more details, you can check out here...
Error on sm bus controller driver
Good luck.
Thanks for using FixYa.
to install SM BUS controller driver you need to install chipset driver of your motherboard. It is also used to install Audio devices. Go to the compaq website and look for your make model and install the requied driver
You will need to get the drivers. These are motherboard drivers. If this is an OEM computer such as a Dell, you can get the drivers from their site. If you built the computer yourself, the motherboard manufacturer's website should have a whole section of files you can download for that model.
Hi
This is the software issue. Need to install the appropriate software to reslove this issue.
1.Ethernet controler - Need to install the chipset driver and the Lan driver
2.Pci bus device - Chipset driver
3. sm bus controller - After installation of the Chipset driver - Right click on the sm bus controller and update the driver - select install from specific location - i will chose the location- Select the model and hardware type as thermal sensor
next - follow the instruction.
4. video controller - Need to install the VGA or Display driver
5. video controller (vga compatiable) - Need to install the VGA or Display driver
goto to system devices look for the question mark, right click, and try reinstall the drivers again, this should normally work and reboot your machine and the drivers should be there.
may be the bus driver you are trying to install may not be compatable for your machine, check with the user manual to see what bus derivers you can install
how can i install sm bus controller driver
