SOURCE: My Bosch Axxis WFL pump drain blocked. I had a
Hi there, i have prepared two links. The first one is the original manual you requested and the second link refers to the quick reference guide.
Click here for the first link to your original manual.
Click here for the quick reference guide.
SOURCE: remove bosch axxis 2060 washer motor
Remove the back panel to get to the motor which is at the bottom at the back. Notice two bolts holding the motor into the mount. Remove these two bolts. Notice the back part of the motor is sitting in the mount with black rubber washers. Carefully, pull the motor forward, and this will be abit hard. You can take a flat head screw driver and tap down (in between) on each front plastic washer and the motor will slowly come forward. Becarefull because there is a wire harness still attached to the motor. You have to take wire cutters and clip the placstic band holding the wire harness to the motor. Then grip the harness and wiggle it free. Then remove the single wire also. Putting the belt back is a bit tricky too. Make sure you put back the two black rubber washers and the two front plastic washers.
SOURCE: need instructions to stack Bosch Axxis washer & dryer - 24"
You can find the manuals at this link
http://www.bosch-home.co.uk/customer-service/download-instruction-manuals.html
