HH Floor Sanding Perth provides the best timber floor sanding, polishing and cleaning services in Perth for a long period. We provide fully integrated cleaning floor Sanding Perth
https://www.hhfloorsandingperth.com.au/
I know this is an old question but it might help others.
Use the laminate flooring calculator in the link
Multiply the width x length of the room, then divide the answer by the area that each pack covers.
Laminate Flooring Calculator DIY Laminate Floor Free Help and Advice on...
You get an idea on how much laminated floor you will need by
measuring the length and the width of the rooms that you plan on installing
laminated floor, multiply the length by the width and add 10 percent for
installing errors and variation in floor design.
First, you can get the exact visual design that you wanted
and it will cost you considerably less. Second, laminate flooring can be
installed above and below the grade unlike hardwood flooring. Moreover, the
laminate flooring is installed without using any nails or glue which make it
much easier to it yourself. Furthermore, laminate flooring is extremely
durable, easy to maintain and can be replaced easily.
Laminated floors can be used in any room you would like
although there are some laminated floors that are more sensitive to moisture.
If you want to use laminated floor in your bathroom you will need to prevent
water from core material of the floor.
