This all happens within 2 seconds and I shut if down before i have bigger issues. spinning blade by hand is not smooth (choppy) blade will not freely spin after i let it go. whats up with it?
SOURCE: hand crank binds
The bearings may be packed with sawdust. Clean it out, look for any place where there could be movement and squirt WD40 in those areas, while cranking. This may free it up.
SOURCE: I inherited an older Delta 10 inch table saw.
Two easy possibilities are that the blade is dull or that the wire is too small. The wire is likely to be a problem if you are using an extension cord. You could move the saw near to an outlet that you know to be wired with 12 gage wire (not 14). Or you could buy as short as possible 12 gage extension cord.
If being underwired is the problem, you will notice that the motor comes up to speed much faster when wired adequately.
You might also buy a cheap new blade to rule out the dull blade problem. If neither of these fixes the problem, then the motor has become "weak" because it has overheated just enough to cause some minor shorts between the windings. (If the shorts are major it won't turn at all and will trip a breaker.) In this case the motor can be rewound, but it will probably be cheaper and easier to just replace the motor.
Good luck,
Al K
