Setting the Sang Tai 6168 S Bird Clock to chirp during specific hours, like from 6 am to 9 pm (a 15-hour cycle), can vary based on the specific model and its features. However, here's a general guide that might help you set it:
Locate the Controls: Look for buttons or switches on the clock that control the chirping sound or set the clock's functions.
Check the Manual: If you have the user manual for the clock, it's the best resource. It typically contains specific instructions on how to adjust the settings, including setting the hours for bird chirping.
Setting the Chirping Hours: Look for any controls related to setting the active hours for the bird chirping. There might be separate buttons for adjusting the chirping duration.a. Press and hold the button or combination of buttons that correspond to setting the chirping hours.
b. Use the buttons or switches to navigate and select the start time (6 am) and end time (9 pm) for the bird chirping.
Confirm the Settings: Once you've set the desired hours for the bird chirping, confirm or save the settings according to the clock's instructions.
If you're unable to find specific instructions or controls, referencing the user manual or contacting the manufacturer's customer support might provide clearer guidance on how to set the specific hours for the bird chirping on your Sang Tai 6168 S Bird Clock.
SETTING THE TIME: ( Remove all batteries before setting) 1. Turn the hand set knob in the rear of the battery compartment clockwise or counter clockwise to read 10 minutes before 12:00 o'clock (11:50) 2. Insert three " AA" batteries into the battery compartment 3. Now turn the handset knob clockwise to adjust the desired time. Note: Each time the set test button"red" is pressed, this sets the birds melodies to the next hours bird. If pressed, you must follow the instructions above to reset properly or you will not hear the correct melody with the correct bird.
Take out all 3 batteries. Move the hands to 5:50. Put batteries back. Start turning the white dial to correct time. As you're turning, if the clock is silent after 9 o'clock, you are on PM. For am, continue turning white dial to 6 o'clock when the bird sounds will start again and then to the correct AM time.
