I replace the thermostate knob and worked fine for a few days and now i plug in a few minutes and shuts off automatically
Check this out: may be your hot rod has absorbed too much moisture
From Traeger:
Why won't my Grill Ignite?
SOURCE: Traeger BBQ trips circuit breaker
Mine is doing the same thing, but it does it within seconds of turning it on. I'd assume you as well have the digital thermostat. I've narrowed it down to what I believe is the hot rod igniter (or the purple connector). Unplug it and it should eliminate tripping and order new part or get warranty part.
SOURCE: My Traeger keeps tripping GFI
I think you have already discovered that the outlet is not at fault. So, now you have to troubleshoot the electrical parts of the grill and their wiring. Most of this you can do with a visual inspection, looking for frayed wires, incomplete connections or bare wire(s) touching the metal framing of the grill and even a circuit that is wire incorrectly.
In case you have misplaced your Owners Manual (which has a wiring diagram) have included a link to it that you can download and print for future reference. Hope this helps you to further troubleshoot and solve the problem. Please let me know.
http://www.traegergrills.com/Media/pdf/Manuals/BBQ075_Manual.pdf
