You may have internal engine damage . broken cam or can.. try to turn the engine manually with a wrench to see if there is any problem while rotate it. In the cold weather when you start engine especially been sitting for too long, engine part need to be lubricated fast otherwise damage it will occur. check and smell the engine oil for strange condition
I did try by hand and it turned over OK it was I lill hard but it is a big block.could I have shorted out the computer or the crank sensor or the cam sensor I don't know how to check.I am by Sat a while I mean maybe 2 weekswhen I bought the new starter the guy said that that typically happens to the starter when there is a backfire
SOURCE: Truck won't start, when ignition turned console lights up but everything else is silent
Sounds like the neutral safety switch may be faulty. try putting the shifter in neutral, then attempt to start it again. If this doesn't work, try holding the key in the position as you would to start the engine while moving the gear shifter back nad forth perhaps youl'll then hear , at some point, the starter engage...
SOURCE: 87 f250 drained brand new battery
I would first have the alternator checked by an auto electrician to ensure it is working correctly and is providing the correct volume of current. It may be faulty and when driving you will be drawing battery power instead of power from the alternator to run the electrics. This will drain the battery.
Alternators do not last forever and if you are still running the original unit it is likely to be on it's last legs and you will need a replacement unit.
SOURCE: Problem is with 2003 Nissan Sentra - was left
Sounds like the fuel pump is bad.... I would have the codes read and start there... but my imediate suspicions are the fuel pump.
It sounds like you have a bad pcm.
