I turned the oven door to the cleaning setting after locking the door. Now I can't unlock it. I also don't know how to tell when it's done cleaning. For some reason the coor locked and I cannot get it open
Try throwing the electrical breaker off and then on to see if it will reset. If not you could put it through another cycle to see if its a jammed armature. However either the door lock motor armature is jammed or the motor is the problem or the solid state did not recognize the cycle was over. If you open the breakers and remove the covers to access the mounting screws you can work the unit out of the wall. Be sure to place some heavy towel or card board on the ground to keep from damaging the floor. Watch placement of your hands and depending on your fittness level you may need a hand pulling and replacing the unit. Test the electrical supply to ensure that its not energized. Then try disengaging the lock armature. IF YOU OPT TO REMOVE THE LOCK THEN THE UNIT SHOULD NOT BE USED IN THE CLEANING CYCLE, EVEN THOUGH THE UNIT SHOULD NOT FUNCTION WITH THE LOCK DISENGAGED, YOU NEVER KNOW ABOUT ELECTRONICS AND IF IT RAN IN THE CLEANING CYCLE SOMEOEN COULD OPEN IT AND GET BADLY BURNED. SO DONT DO IT. You should be able to order the parts needed on line at this website. http://www.searspartsdirect.com/partsdirect/index.action?intcmp=xsite_Sears Best o Luck :?) DRRXR
SOURCE: My Kenmore Oven door won't unlock
It appears your door lock mechanism has failed in this instance.
First - unplug the unit for 40 minutes and re-try.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
After cleaning cycle oven stayed locked. Tried shutting off breaker, but oven did not unlock self or clean again
