Wont stay running long new conputer
SOURCE: Security light flash on dash won't turn over or stay running.
I CAN HELP YOU. DISCONNECT THE BATTERY FOR 5 MINUTES. RECONNECT AND USE YOUR KEY TO LOCK THE CAR. THEN OPEN THE CAR WITH YOUR KEY. THAT RESETS THE SECURITY SYSTEM. GOOD LUCK.
SOURCE: Car won't stay running
Mechelle, If your check engine light came on, then the faulty sensor(s) should have given your ECC (engine control computer) a code. If you know how to extract codes from your car, this may provide you with the exact problem(s) your car is having. That would be my first recommendation. Based upon what you described, if the car stalls out in Park, Reverse or while idling at a traffic signal, then my first guess would be to clean or replace the Idle Air control valve. This is usually located close to the throttle body assembly. You can pick up one of these at your local auto parts store, I looked up the part for your make and model @ www.AutoZone.com and found one for $32.99 (PN: AC95150A). However, keep in mind this may not be the solution to your problem and without pulling codes, it’s like shooting an arrow in the dark. You also said that your locks, windows (electrical) will not work when the car is running, do your accessories work when the car is not running? Hope this helps.
SOURCE: runs rough at start up,then runs okay, Hesitiates
you have a bad injector, if you have A... as it states on the top of the motor 2.8, 3.1 L MULTI PORT and dies or idles really rough and the exhaust smells like strong gas. most likely you have an injector that has shorted or is shorting out and from my experiences usually after a road trip or using fuel injector cleaner or buying a used car. it will cause half the motor to not run or run poorly VERY POORLY or even burn out 1 injector fuse out of 2 under hard acceleration or idles but as soon as you touch the gas pedal dies. but only if it is a MULTI PORT fuel injected motor. ive heard you want to try and replace them with bosch injectors out of a 2.9l ford bronco/ranger. only attempt if you got the mechanical know how sometimes if not done right will leak gas because of the injectors being kinda different length. research before attempting.
SOURCE: 1997 buick regal gs starts but wont stay running.
Your fuel pump ballast resistor is bad if it's a super charged engine. you will find it behind the battery other side of the wall kind of hard to find. it's a large white ceramic rectangle this takes the load from the fuel pump allowing it to run.
Testimonial: "hit it right on the head ,replaced ballast resistor,which the dealer didnt even know what it was,and started right up ,thank you much sir"
