Hi !..ok you tv problem is in power supply. need be replaced 9 capacitors, (3300mf - 10V) in main power supply board, that fix yu tv..
Without testing I wouldn't suggest the Power supply is not defective: 1st, the control module is working because you gave it an ON command, 2nd the SMPS has received the the start up. The secondary voltages for the Y sustain and Z sustain modules are shutting down, probably due to a shorted IPM on either of the two modules mentioned. This problem is one you should contact your nearest svc center for a complete diagnosis. If I can be of any other assistance please e-mail me.
Mine is doing the same thing
