Do I have to disconnect sprayer hose from below sink in order to tighter sink retainer nut?
You can find replacement parts on amazon, click here Award winning faucets and shower heads and take a look. Cheers
SOURCE: Loose handle on my Moen single handle kitchen faucet
Yes it is fixable and easy.To save you time because I belive you will be needing a new part from Moen I am sending you this easy link to quickly resolve your issue. Just be sure to tell Moen you are original owner of faucet and all parts are lifetime free including shipping. Go Moen!!!
http://www.moen.com/contact.cfm?location=TopNavCustomerSupport
Thanks and Please Rate jj505
SOURCE: I'm almost finished removing a Moen single handle
Turn it the opposite way. They are made to go on just the opposite of what you think you would do to turn them
SOURCE: I am also trying to remove a Moen single handle
the white plastic clip needs to be removed. squise the clip together and push it out at the same time should come out fairly easy, then just pull the black piece off.
SOURCE: moen single handle kitchen faucet, Hot water and
Hot water line connected to left side of faucet? Did you replace tap set, or just cartridge? Cartridge may be out 180 degrees.
SOURCE: moen faucet removal
you will have two mounting nuts at each end and two water line to disconnect for removal under the sink on any faucet made
Thanks for your advice, guys. I was able to borrow the extended socket wrench I needed to tighten the nut. Yes, I did have to disconnect the sprayer hose in order to reach the fastening nut with the wrench. Mission accomplished! Thanks again, Grant
