Question about 990 And 950 Responder SST Remote - 7701P
Set up the car remote
Prgram my python car remote 7701p
    New Friend:
    Problem Solver:
  • 6 Answers
A 7701P is a remote transmitter. It is not an alarm. You must know the alarm's model because different models have various ways of programming transmitters. In other words, you do not program the 7701P. The frequency is already fixed. You must program your security system to teach it that transmitter's code. Look up the manual for your security system. Instructions will be there. This typically involves turning the ignition on/off a specific number of times and pressing a valet/programming button (or switch) a certain number of times and then pressing a button on the transmitter.
Posted on Feb 01, 2013
My 7701p is on vibrate mode...how do i get out of it
Press and hold programming button on the back of the remote until one long beep is heard, Programming mode has been entered. Use the lock button to toggle between vibrate and beep. If no action is taken after five seconds, the programming mode will be exited.
Apr 12, 2011 | 990 And 950 Responder SST Remote - 7701P
Need to see a picture of the toggle switch since this is my sons car and I do not have the remote start just the ignition key and alarm is gong off
the toggle switch will not disable it. you need to turn the key to the ON position WHILE the alarm is sounding (so if the sole virtue of turning the key triggers the alarm you will need to turn the key off and back to on), then press and release the valet switch once.
see the picture below to know what you're looking for.
http://www.carstereoneeds.com/images/dei-8631.jpg
Mar 06, 2011 | 990 And 950 Responder SST Remote - 7701P
How to turn light on the python 990 remote?
If you just want the LCD backlit turned on, press and hold the program button on the back of the remote until the remote gives a long tone, that indicates that you've entered programming mode. Then within 5 seconds of entering programming mode press the the unlock button. The remote will beep once for backlight on and twice for backlight off. In the "on" setting your backlight will turn on each time a button on the remote is pressed. It will run down your battery faster though. It's the same for both the 990 and the 950 remotes.
Nov 16, 2010 | 990 And 950 Responder SST Remote - 7701P
My remote will not do anything. i try to lock my car and it gives two quick beeps three times and im right by the car so im not out of range.
you will have to overide the system with your valet switch, its either a bad brain or bad antenna, its a common issue with viper
Sep 09, 2010 | 990 And 950 Responder SST Remote - 7701P
How do i remote start my car with this python sst remote?
I believe you press the lock and unlock at the same time.
Jul 04, 2010 | 990 And 950 Responder SST Remote - 7701P
When I start my car using my 950 Python auto start remote, the car runs for only about a minute then turns off. How can I fix this?
Does your vehicle surge at all when its running becuase if the Python see's any fluctuation in RPM it will kick out.
Dec 09, 2009 | Install Essentials 489P Responder 2-way...
When i bought the car it was disarmed maybe cause it was towed?
Do you have the alarm's remote fobs? If not do you know where the valet button lives? It's a little black button hid somewhere under the dash. Anyway put your key in ignition turn key to "run" position and within 5 seconds push the valet button and that should stop the alarm and allow you to start the vehicle. OK after you get the vehicle started turn it off and hit the valet button again. The blinking LED should be solid not blinking and that's telling you your in valet mode which means the alarm is off, the conviencince features like keyless entry and remote start will still work but the alarm is standing down.
Aug 11, 2009 | 990 And 950 Responder SST Remote - 7701P
2way remote for Python 872 not working
Make sure that the responder is set for your car. this responder can work for multiple cars...The owners manual tells you how to check.
Dec 29, 2008 | 872 Responder LE Security Remote Start
990 And 950 Responder SST Remote - 7701P Logo
211 people viewed this question
Top Python Vehicle Parts & Accessories Experts
rjivaro
john h
cartoys4u
Are you a Python Vehicle Part and Accessory Expert? Answer questions, earn points and help others
