Fisher and Paykel Active Smart E522B Bottom Freezer Refrigerator Logo
Anonymous Posted on Feb 27, 2017
Alarm sounds when defrost cycle ends & Green freezer light flashing continuously, Not cooling or freezing properly. Please see notes
Long story following, but briefly at first. I am trying to do repairs myself. The first thing happened was alarm, and then noticed that freezer door seal had become dislodged. Pushed it back into position, but some time later alarm sounded again. *Evaporator icing up, but defrost cycle appears to be working correctly. *Defrost element is heating and melting ice, very little if any remaining at end of cycle. Also tested continuity (136ohms). Evaporation tray on compressor has been full for a few days. *Found broken wire on Freezer Compartment fan and soldered to fix. Tested and is working. Success I thought, but alarm still sounds and still not cooling properly e.g. 12 degrees fridge & -5 degrees freezer. Temp Settings on control panel in the middle. *Both fans seem to be working but only operate at high rpm for about 15 seconds after closing door. Noticed fridge fan continues at lower rpm but not sure about Freezer fan. Haven't heard fans at high rpm other than after door closing. I don't know if that's normal? *Compressor cycling on and off, but running a lot of the time. I'm basically in the dark, but I'm thinking the freezer seal leaking might have caused evaporator to freeze up. Fan may have hit ice and broken the wire. Having repaired the wire, I don't know why we still have the problems. I've removed control panel inside fridge and looked at circuit board, can't see obvious damage. Thought I could check the continuity of the evaporator sensor there, but wires don't go to it. Don't know how or where to check other sensors, or what readings should be. If I knew what the stage number of our fridge was I might be able to find it here maybe - http://appliancehelponline.com/fisherpaykel.html Thanks ahead of time to anyone that can help in any way. Cheers Ross P.S. I've been keeping notes of what's happened and what I've tried in a word doc. I could paste it in here, but I'm not sure if it would be taking up too much space or going into too much depth for my own good???
4 Related Answers
Anonymous
  • Posted on Feb 26, 2010
SOURCE: Fridge and freezer are alot warmer than normal
fridge not cooling pruperly
kel1guy2002
Kelly
  • 3740 Answers
  • Posted on Jun 21, 2011
SOURCE: Hi, I have a Fisher and Paykel E402B
Your automatic defrosting circuit is not working. There are several components that can stop the defrosting process:
1. The defrost control
2. The defrost element
3. The defrost thermostat
Any one of the 3 can open cause the automatic defrosting process NOT to work.
If the defrost control fails, it just stops defrosting and ice builds up on the evaporator coils.
If the defrost element fails it will go into the defrost cycle and not cool again until the internal temps reach 60 Deg F.
If the defrost thermostat fails in the open position the heater will not heat up and the freezer will ice up.
There are 6 models of the R402B so I was not able to narrow down a source your exact parts data.
However, if the defrost control has failed the good news is the most expensive one is $18.95 AUD
Hopefully this gives you something to go on. I think it will either be the defrost control or the thermostat. If you can locate the defrost control turn it until it clicks ONCE and see if the unit shuts off and completes a defrost cycle. If it heats up but does not complete the defrost cycle again your looking at a problem with the defrost thermostat. If it does not heat at all then the problem is the heating element.
The defrost control will have 2 sloped tabs on it so that you can only turn the control one direction. The defrost control dial with the tabs will be no larger than 1/2 inch in diameter.
UK Parts: http://www.partmaster.co.uk/cgi-bin/search.pl?query=Fisher+%26Paykel+E402B
AU parts: https://www.statewideapp.com.au/shop
You most likely will have to make a "contact" enquiry at either site above. For the defrost tmer, heating element or the defrost thermostat.
Thanks for choosing FixYa,
Kelly
Testimonial: "Thanks heaps. You guys are great."
Anonymous
  • 3773 Answers
  • Posted on Sep 16, 2011
SOURCE: Ice maker not working Freezer temp
FREEZER FAN MOTOR MAY NEED REPLACED. THE EASIEST WAY IS TO TAKE OFF THE BACK PANEL IN FREEZER AND REMOVE THE FAN
MOTOR, TAKE IT TO THE NEAREST APPLIANCE PARTS STORE WITH YOUR MODEL NO.
EASY JOB.
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
need more help go here:
http://www.applianceaid.com/procedures.html
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
Bill Boyd
  • 53816 Answers
  • Posted on Jul 25, 2015
SOURCE: Compressor running continuously. Hearing surging sound. Both fridge & freezer not cooling.
there may be a blockage in the evaporator tube in the fridge sections and the only way to establish what the fault is will be to have fridge technician run test on it
My Hotpoint FUFL1810P that keeps beeping and the lights inside are flashing when the door is opened, I have reset by turning the power off and on again and also by turning the freezer switch off and on....
Something to think about from the manual for your freezer. Also I would check the temperature of your freezer with a thermometer to make sure it is freezing ok .Troubleshooting
If the appliance does not work, before calling for Assistance (see
Assistance), check for a solution from the following list.
The green POWER indicator light does not illuminate.
ā€¢ The plug has not been inserted into the electrical socket, or not
far enough to make contact, or there is no power in the house.
The motor does not start.
ā€¢ The appliance comes with a motor protection control (
see Start-
up and use
The indicator lights are on but the light is dim.
ā€¢ Pull out and reverse the plug before putting it back in the socket.
a) The alarm sounds.
a) The refrigerator door has remained open for more than two
minutes (the buzzer will stop sounding when you shut the door) or
the correct switching-off procedure was not followed (
see
Maintenance
b) The alarm sounds and the two yellow indicator lights
flash.
b) The temperature in the freezer is too high. Check the quality of
the food products and dispose if necessary.
+ buzzer =
Heating is excessive
c) The alarm sounds and the two yellow indicator lights
as well as the green one flash.
c) The temperature in the freezer has reached a dangerous level.
The food must be disposed immediately.
+ buzzer =
Heating danger
b/c)
In both these cases the freezer will maintain a temperature of
about 0Ā°C so that the food does not re-freeze.
To turn off the acoustic signal open and close the refrigerator door.
To restore normal operation bring the FREEZER OPERATION knob
setting to
(off) and turn the appliance on again.
The green POWER indicator light flashes.
ā€¢ The appliance is not operating correctly. Contact the Technical
Assistance Centre.
The refrigerator and the freezer do not cool well.
ā€¢ The doors do not close properly or the seals are damaged.
ā€¢ The doors are opened too frequently.
ā€¢ The OPERATION knobs are not on the correct setting (
see
Description
ā€¢ The refrigerator or the freezer have been over-filled.
The food inside the refrigerator is beginning to freeze.
ā€¢ The REFRIGERATOR OPERATION knob is not on the correct
setting (
see Description
ā€¢ The food is in contact with the back inside wall of the refrigerator.
The motor runs continuously.
ā€¢ The SUPER FREEZE button has been pressed (rapid freezing):
the yellow SUPER FREEZE light is on or flashing (
see
Description
ā€¢ The door is not closed properly or is continuously opened.
ā€¢ The outside ambient temperature is very high.
1helpful
Kenmore upright freezer not freezing
Kenmore & Whirlpool refrigerator frost build up in freezer not ...
? 7:02
www.youtube.com/watch?v=gVXT7pZyk_o
Sep 12, 2013 - Uploaded by ApplianceVideo.com Service a Kenmore Upright Freezer which has the following problems: Not Cooling Properly At: http ...
Freezer Troubleshooting - What to Check Before You Call a ...
www.realestate.com > Realestate.com Blog > Articles
Aug 12, 2012 - Alternatively, if the freezer is in a defrost cycle, it will not kick on immediately, the temperature ... Refrigerant circulates through coils, spreading coldthrough the unit interior before .... We have a kenmore upright deep freezer.
Why is Zanussi frost free freezer alarm always flashing
Because it does not achieve the correct temperature (for example: -18 degrees centigrade).
For a more precise answer I need more information.
A lot of things may be incorrect:
- Doesn't work defrosting cycle
- The cooling fan is not working
- Too much ice on the evaporator battery
- Faulty thermostat or NTC sensor
- Faulty cooling system (gas leak)
- Compressor
- Electronic
Dado
Fridge is not cooling. lights are working. freeer is working
Its defrost problem, the freezer should cool, then freeze, then defrost cycle should start. In your case freezer is cooling, then freezing, but its not defrosting. That's why fridge section is not cooling.-------
Click this link below and follow the troubleshooting:----
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
This will help.Thanks.Helpmech/.
I cannot locate my owners manual for my Imperial upright commercial freezer. I need to know how to defrost it
Hi the following should tell you all the info about the controller
Directions for Accessing and Setting G3 Series Digital Controllers
Changing the Temperature
Instructions for changing the desired temperature
1) First, press set for 1 second
The current set value will begin flashing after a few moments
2) Second, increase or decrease the temperature value by using the up or down icons
3) Lastly, press set to confirm the new value
Manually Setting Defrost
Instructions for manually setting automatic defrost
1) Press down the snowflake icon for more than three seconds
note that defrost will only begin if the temperature inside is equal to or less than 45
degree F.
2) Defrost will last about 25 minutes and then return to normal cooling or freezing
cycles.
Using Flash Cooling or Freezing
Instructions for Using the Flash Cooling or Freezing command
1) First, press the up and down icons together for more than 3 seconds
2) The refrigeration unit will immediately begin cycling to quickly reach the desired
temperature set point.
3) ** Flash Cooling/Freezing Option must be first set on the Configuration Parameters
Menu: Go to CC (continuous cycle duration) and enter a value. The value entered will
be the amount of time (in hours) the Compressor will run continuously to pull the
temperature down. Note: Flash Cooling may go below the temperature set point.
Eg. CC = 2 = 2 hours of Flash Cooling/Freezing.
Accessing & Setting Configuration Parameters
Instructions for Accessing & Setting Configuration Parameters
1) First, press set for 3 seconds, the display will show PS, then press set again.
2) Next, enter the password #22 to go the menu, press set.
3) You can scroll within the menu by pressing the up or down icon.
4) Go to the Carel controller detailed menu chart for specific controller settings. Click
Here.
5) To change the values, go to the menu listings ( C0, C1, D0, D1, F0, F1 etc), press
Set, the up or down icon, then Set again to complete the changes.
6) Finally, to Save all the changes made in the Menu, press and hold Set for 3 seconds.
Note: One of the parameter menu listings must be accessed to Save properly by
pressing set for 3 seconds. Saving by pressing Set for 3 seconds outside of the
parameter menu listings (ie, CO, C1, DO, D1, etc) will not save the changes.
7) If you do not want to Save the changes made, do not press the buttons for 60 secs
Regards
Gordon
Defroster get red hot
Kenmore Frostless Upright freezer model# 23971. The alarm sounded, all contents in freezer is frozen solid. We turned the alarm off, but the red light continues to blink. How do you reset the alarm and stop the red light from flashing? It has been 3 days now and every time we have check to see if the contents has started to defrost, there is no signs of defrosting, everything inside of the freezer remains frozen solid.
4helpful
Both Lights flashing and fridge not getting cold
I turned the fridge and freezer off using the circular dials, I then turned the unit off at the mains. Left it for a few minutes and then turned the power back on. I then turned the circular dials to "max" and then depressed the super cool and super freeze buttons to turn this facility on. This time they came on normally (not flashing) and no alarm sounded. The fridge and freezer then started to get cold. Once the unit had been running for several hours I then turned the dials to the 3/4 mark and depressed the super cool and super freeze buttons again to turn them off. Over night the fridge and the freezer appear to be working properly so I hope that my problem is solved. Maybe the unit just needed to "settle" before being switched on?
Sep 03, 2009 • Freezers
1helpful
Alarm
the alarm is there to warn you that the freezers not up to set tempature.. The reason as I see what you wrote would be a stuck or burnt out auto defrost timer motor. or the units got a leak in the refrigerant line??? good luck
Top Fisher and Paykel Refrigerators Experts
Grand Canyon Tech
Grand Canyon Tech
NOEL
NOEL
john h
Are you a Fisher and Paykel Refrigerator Expert? Answer questions, earn points and help others
