Is it charging? Does it Fully Charge? When you say "not holding a charge", how long are we talking about? Minutes, Hours? Battery life depends on what your doing and what is running and other factors, Some aftermarket batteries aren't very good. Inexpensive batteries are cheap for a reason.
well your laptop should stay on when you take it off of your charger if its charged. Usually when someone has the problem it means the battery on their laptop is no good. This usually happens when you let your laptop die and lose all its power from the battery this can really damage your battery. Thats the only thing I can think that happened. Your probably going to need to get a new battery. I hope I helped you.
Are you using vista or xp?..The laptops to conserve power will dim the screen , you can , however, change it to brighter by pressing the "fn" key which stands for "functions"key. while pressing that, you should have another set of keys either to your right or obove your left finfers with the symbol fo a sun with arrows pointing up and down..press the fn and tap the up arrow key to increase the brightness.
The problem associated with Laptop not being able to power from the Battery, even if the Battery is new, can be attribute to the mainboard charging Electronic. The charging electronic in Mainboard is perharps defect. If your laptop still have warranty, this is the best time to change the mainboard.If not, seek for a qualified technician to check the PC, run the system, make Bios Update, and have the mainboard checked.
