We have a Whirlpool Gas Dryer, model: LEQ8858HQ0 and the drum has stopped spinning.
So far, we have tried opening the door & moving it by hand, but it won't move. Not sure if the dryer is belt driven, but tried to take it apart. Right now, we can't figure out how to remove the fan motor out to get to the area where the belt might be. If anyone has any ideas, please help.
Any assistance is greatly appreciated! Thanks!
Whirlpool Ultimate II Care GAS dryer
The dryer vent has been off for quite a while. The dryer is turning on fine but will not heat up. We have put the vent back on and cleaned the fur off of the back side of the dryer. Unsure how old the dryer is. Any ideas? Thanks, Lisa
No spin, or lite spin try these: bare in mind that many times there is no spin it can be due to a clogged water pump so check it for debris and or broken propeller.
Other items to check Using a multi meter check for continuity the door switch, which when bad may not allow agitation or spin. Bare in mind the lid switch assembly can fail either mechanically or electrically.
Check the clutch, brake assembly and transmission, one way to check for slipping is to get under the machine after a spin cycle ( this is if u get a lil spin but not much leaving clothes still wet) mix in a spray bottle a lil water and some dish detergent, then spray it on the clutch assembly ( the metal round pc. Connected to the tranny) if it sizzles and steams up then u know its bad and slipping. Another way to check clutch if u get no spin at all? Is to take it out and use ur hand to try and turn the inner spring assembly pushing it around the inside? If its very easy, it BAD should be hard to push by hand.
Or try the hand test:
If no hammering sound has ever been heard out of this machine, one of the unofficial tests we professional appliantologists will do in the field is called the Hand Test. WARNING:This test is not sanctioned by Whirlpool Corporation; it involves bypassing safety equipment and then putting your hand on and near rotating machinery which could result in injury, dismemberment, disfigurement, disembowelment, mangling, hideous screaming, and a ****** *****. Proceed at your own risk! Have a nice day.
- put the timer on a spin cycle and open the lid- grab the inner basket with maybe 30% to 40% of your hand strength with your left hand
- turn on the machine and bypass the lid switch by depressing the lid switch with a key until the machine begins to spin
- if the clutch is engaging properly, the basket should immediately begin to spin and slip through your hand
- if it takes very little force to stop the tub from spinning, the clutch needs to be replaced.
Next check the motor coupler which engages the tub and tranny to the motor. ( if its bad u usually get no wash or spin or very little of either)
Next if belt driven check for a loose, worn or broken belt. And on some models there is no clutch but rather what is called a splutch. And a MODE shifter. These can go bad and effect the spin cycle.
On some front load models u may need to check the STATOR assembly.
The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
Sometimes a no spin machine can be due to a plugged waterpump hose or obstructed water pump propeller. Check these by eye and hand. And in some models check with a meter for continuity and voltage.
LID SWITCH TEST- next step is toremove the cabinetand jumper the lid switch harness (tan to gray). Put the unit in spin and watch the shiny metal clutch disc that is on top of the transmission where the shaft comes out. If the machine starts and runs in spin, check to see if the disc is spinning. If it is, then the problem isnot in the gearcase- look for trouble in theclutch,basket driveor the tub drive block
If, on the other hand, the disc is NOT spinning, check for a problem withthe motor drive coupleror one of its retainers. This washer doesn't have a belt. Instead, the motor is directly coupled to the gearcase by a drive coupler; that's why it's called a direct drive washer.
Read more:Diagnosing and Repairing Spin and Agitate Problems in a Whirlpool / Kenmore Direct Drive Washer
http://fixitnow.com/wp/2010/07/07/diagnosing-and-repairing-spin-and-agitate-problems-in-a-whirlpool-kenmore-direct-drive-washer/#ixzz3XW7eZwiN
By the way my advice is free cuz God is good!
Diagnosing and Repairing Spin and Agitate Problems in Whirlpool Kenmore...
SOURCE: Whirlpool Ultimate Care II washing maching but will not spin.
lid switch is bad chance are you can by pass this by removing the timer header and crossing the outer wire on the lid switch that it mounted closest to the lid not the power cord this will tell you if you need a switch
SOURCE: Whirlpool Ultimate Care II - Gas Dryer - Drum Won't Spin
If you are handy with tools, try to remove the back panel and feel the belt that should surround the drum. If access is that limited, try to turn the dryer on its side and you can get to the motor from the bottom. But like the guy said before, call a pro if you can't do any of this.
SOURCE: Where is the pilot light on the Whirlpool Ultimate Care II Dryer?
Hello gigiknoll
Welcome to Fixya
My name is Huum,
This model should be electronic ignition and does not use a pilot light.
The igniter may be faulty.or the gas module may be faulty.
Pilots are a thing of the past!
This requires a tech to test it with equipment.
Thank You For trusting us with your question
Please remember to leave a solved rating before you leave!
