SOURCE: Canon SD550 Digital Zoom Not Working
Digital Zoom is best ignored in any camera it simply blows up a section of an image already taken, You can do that far better with an image editor in the computer. As for the Optical Zoom - it does indeed seem to be repair time- As it is only a year and half old- may be Canin will be sympathetic and offer a cheap swap out.
SOURCE: Samsung L85 camera image issues
If your camera is still under warenty here is number of the repair center in Ca. 310 632-1234. Have model number and serial of camera at hand. They may have you go on line to their web site http://www.samsungcamerausa.com/ and fill out a repair request.
Forewarned :I purchaced a L85 new before
Thanksgiving and it did not work out of the box at all. Sent in camera and it was returned on Dec. 20th. I sent the battery with camera and none was returned. After buying another battery and charging, to my frustration the camera worked only enough to extend the lens and flash the LCD screen and that's it. I am trying to get an exchange from seller but am not to confident this is going to happen. Lots of emails back and forth but no progress.
Hope you have better luck then I am having.
SOURCE: Digital camera got dropped into
THIS SOUNDS TERMINAL, BUT YOU MIGHT TRY USING CANNED AIR LIKE YOU USE TO BLOW DUST OUT OF YOUR COMPUTER, AND SEE IF IT HELPS ANY. MOST OF THESE CAMERAS ARE MADE WITH THE IDEA THAT THEY WILL NEVER BE TAKEN APART OR OPENED FOR CLEANING ETC. SO, THAT IS THE ONE PROBLEM YOU ARE FACING. I DOUBT IF IT WOULD BE WORTH SPENDING THE MONEY TO SEND IT IN TO BE CLEANED. THAT CAN GET VERY EXPENSIVE IN A HURRY, PLUS TAKE A GOOD MONTH OR MORE FOR THE REPAIR. SORRY, I CAN'T HAVE MORE CHEERY NEWS, BUT THINGS LIKE THIS JUST AREN'T TAKEN INTO ACCORD WHEN THEY MAKE THESE CAMERAS. IF I CAN HELP MORE JUST REPLY TO:
ARCLIGHT1217
SOURCE: EasyShare C875 dropped, won't focus
yes i'm afraid it is a lost cause as the camera has now suffered from shock damage sorry!!!!!
kind regards and please don't forget to rate us
SOURCE: Auto focus not working Kodak V803
is the setup shoing that it is on MACRO? if so turn MACRO off
The non-functioning of the camera can be a fault in the shutter, zoom or auto focus sections and may be due to the failure of the Main control system or the drive. A simple was is to reset and we can try by removing the battery and card for some time. Now replace only the battery and while switching power ON, tap the lens hood on the palm of your hands so as to disengage any dirt or mechanism being struck. You can spray a degreasing spray on the lens hood sides and also assist the lens as it tries to come out, attempt to pull it out slowly while powering ON the camera. Also in some cases you can slid a thin film/paper on the lens hood sides to wipe out any dirt.
Tips to open and check for common faults: http://www.youtube.com/watch?v=v2Mj3Qp3xYU&feature=related
Use some air to blow between the lenses to dislodge any sand particles struck inside. Unless you are familiar with handling of small devices must you try and open. If so check the voltage on the motor drive check the auto focus and Zoom drives, it must be free with manual movement. If jammed the motor can be removed and released. If none of these works then you can think of taking consensus with the service centre.
Get estimate before you decide. It will be good to have it checked at the authorised service as you do not have to run around for spares.
