Whenver plug in my Keurig B70, LCD panel tuned on without press power switch. And indicated "NOT READY, brew temp set" on the LCD panel and Wont do anything.
SOURCE: Keurig B70 Not Ready Message
Unplug the unit for 20 seconds- 1minute. Plug it in again. You should be able to program from the menu. Hope this works.
SOURCE: My Keurig platinum B70 will not pump water through
Please get a hold of the company at the number in the manual, they will send you a new one if they cannot fix it. Magic words, I got it as a gift three months ago, it worked fine until now. Worked on mine. Sending out a new one today. This company works with you until you are happy. and I am getting 4 boxes of coffee! Free!
SOURCE: New Keurig B70 (brewed about 20 cups of coffee)
I had the same problem. I called Keurig. After much back and forth of "do this" "OK, I did that. It still doesn't work" they are going to send me a new brewer in "5-7 days". I just have to send back the K-cup assembly.
SOURCE: My B70 Keurig will not brew. Tried turning power
Here is a tip that I wrote
that will give you some things to try that will help you get your
Keurig coffee brewer working again.
Keurig
Coffee Brewer not making a full cup of Coffee
heatman101
SOURCE: MY KEURIG B70 IS CONTINUALLY PROMPTING TO "PRIME"
Hi, Lauren..
You can download another manual here.
Cleaning any coffee brewer is essentially the same. The easiest way is to brew one or more pots of white vinegar... it'll stink up your kitchen, but it's effective at removing build-ups and mineral deposits. Be sure to follow up these "vinegar brews" with several "plain water brews" to remove all the vinegar!
Also, if your water reservoir isn't clean (open the lid & do a finger swipe), you can use a brush to clean it or - what I do - wad up a paper towel or two, attach it to the end of a long-handled wooden spoon, and use that to get down deep into the reservoir & scrub it as much as you can before the vinegar treatment.
Alternatively, you can spend $3 or $4 for packaged cleaning compounds at stores like Williams & Sonoma.
