I have my cb grounded and a wire ran to the postive side of my battery terminal and the antenna wire ran and my cbs channels wont come up we thought it was jus my cb so we hooked another up and it did the...
Here is the deal, even with out antennas hooked up, you should get at least your channels on your cb showing, no of course you would have all noise and distortion with out antennas hooked up. And sense you hooked another cb up with same results it tells me, number one, it is not most likely your cb. If your channels are not even lighting up, then this tells me it is not getting power. I know you said that the cb is grounded, and there is a wire ran to the positive post of the battery. What I would do first of all make sure proper wire on cb is grounded and not reversed accidentally, but what i believe is your not getting power to the unit, if it was properly installed, there should be a inline fuse from the cb radio to the positive post the wire is connected to on the battery. I believe there is a inline fuse that is blow, or not a good connection on the post of the battery. To test this theory, take a long piece of same size wire gauge, and run direct from positive on battery to positive post on battery, of course making sure that the proper wire off the cb is grounded (must be grounded to something metal, might find different spot to ground the radio if not for sure on metal) If you get lights going on then on radio, then your problem, was not a good connection or inline fuse on positive wire that maybe you didn't see was blown. Let me know Mike
