REPLACED ICE DOOR FLAP BUT SEEMS TO BE STICKING BECAUSE DOOR WILL NOT OPEN WHEN ICE IS DISPENSING.
COULD THIS BE BECAUSE OF TOO MUCH TENSION ON SPRING THAT HOLDS ICE DOOR, OR DOES ICE DOOR OPEN ELECTRONICALLY?
The ice door has a solenoid that opens and closes the ice door. since you were able to replae the door i assume you can take it apart pull it back apart and the crank the door attaches too is connected on 1 side to an electrical soleiod test if the plunger moves up and down freely. also look for heat deformation around the plastic as well. if it turns out the solenoid is bad i would also recomend replacing the the fountain boards as well. I dont think you can put to much tension on the spring..
THANK YOU VERY MUCH .I FOUND THE CARTDRIDGE. IT FELL UNDER THE REFRIGERATOR
