Question about Drywall
I need help finding a stub behind drywall - Drywall
    Habit-Forming:
  • 47 Answers
Your best bet is to go to your local hardware store and purchased a stud finder which are usually not too expensive
Posted on Jul 19, 2019
    Habit-Forming:
  • 50 Answers
Runa an earth magnet over the wall. It will find nails and screws that hold the drywall to the studs. An old way to find studs.
Posted on Feb 09, 2018
  • 575 Answers
You always have a stud on one side of an outlet. Take off the cover and see which side of the outlet the stud is. Now all you have to do is measure 16'' center from that stud to find the next one.
Posted on May 02, 2017
    New Friend:
  • 61 Answers
The stud finders are not expensive but you can sometimes use a magnet to find the nails. Also you might try shining a flashlight across the wall. The putty put over the nails will sometimes show up. Last resort is to tap on the wall and try and hear the areas that have support under them.
Posted on Jan 26, 2013
6ya staff
SOURCE:
How do i find my pay stubs?
hi Brittany.
not sure if this is what you are asking for.
  1. In Personal click Payroll on the left side of your screen.
  2. Click Pay Stubs from the drop-down.
  3. Click the eye icon next to the pay period you'd like to view and download.
  4. Click PDF Version on the right to download a PDF of your pay stub.
How to view, download and print your pay stubs - Help Center
https://support.waveapps.com/.../208621916-How-to-view-download-and-print-your-pa...
How do I access my pay stubs online?Contact your employer's human resources or payroll department and ask about the steps required to obtain copies of your paycheck stub. Some employers might charge a fee for copies, while others provide this service for free depending on the number ofstubs requested.5 Jul 2017How to Get a Copy of My Pay Stubs ' Career Trendhttps://careertrend.com/13372157/how-to-get-a-copy-of-my-pay-stubsSearch for: How do I access my pay stubs online?
or this link.
How do find my pay stubs Google Search
Nov 29, 2017 | Cars & Trucks
How to fix 1 inch holes in drywall
many home improvement stores sell partial sheets . then you cut a plug the right size and spackle it in place .
Apr 06, 2016 | Drywall
When you are drywalling , how do you mark the location of the electric socket ont he drywall yor about to hang in place.
You can either measure up from the floor or the piece of drywall you just hang and then measure over from the wall or the piece of drywall you just hang or you can put the drywall in place and I ball behind it and Mark with a pencil and then cut it out with a dremel tool and you should be good from there. You might want to use a keyhole saw or a roto zip and a Rotozip is the best way to do it but it takes a little practice in order to control it
Jul 22, 2014 | Drywall
Drying out wet drywall
I'm assuming your talking about drywall that was wet during a flood of some type? Recommend you remove all damaged drywall and using a straight edge and a utility knife this can be easily accomplished. After you cut and remove the damage, remove all screws or nails from the studs giving a good surface for the new drywall that your going to replace the damaged stuff with. Get that done and we can move onto taping and drywall compound repairs. Hope this helps.
Mar 16, 2014 | Tools & Hardware - Others
My middle handrail attaching brackets were attached to the drywall with plastic anchors - and they are now loose
Handrail brackets should never be installed into drywall--they must be mounted into the studs behind the drywall so that they will support the weight of the person using the rail. Hope this helps!
Feb 03, 2011 | Garden
Trying to mount blinds in kitchen, walls plaster over carstone. as soon as we hit carstone masonry drill stopped in its tracks!! less than half inch into wall!! really need to be at least quarter inch...
Is there a space between the back of the drywall and the stone? Or is the drywall tight to the stone? Either way, you need a masonry bit, I hope you have one, a hammer drill would be real nice, but you can muscle through it without one. You can try a smaller bit as your first cut , then go to the next size. Makes it a lot easier to drill. If there was a space behind the drywall, they make all kinds of fasteners for drywall only, they will hold quite a bit, but might not be enough for blinds that are going to be yanked on.
Feb 13, 2010 | Black & Decker Drills
Air con charging stubs
One is near the compressor, the other is near the firewall in my mitsubishi triton. I hope yours is similar.Another possibility is behind the front grill.
Aug 07, 2009 | 1993 Mitsubishi Montero
Drywall screws don't go all the way in the first time.
You use the lower speed setting (which has more torque) and the clutch ring, which is just behind the chuck) should be set to a higher value, i.e. 16, 18, 20 or whatever the largest number is on the drill clutch ring.
If you still cannot drive them all the way in, it might be because you are drilling into hardwood studs or supports behind the drywall. If this is the case, you may have to pre-drill (pilot hole) for each screw so the screws are easier to drive in.
Jun 20, 2009 | Dewalt Drills
Can oly get to one 2x4
If you have drywall, you can use heavy duty drywall anchors. If not, you will have to extend the straps and attach at the same point. If you don't have drywall, you can add another post anywhere if your plate is accessable.
Mar 31, 2009 | Quakehold! Bear Claw Water Heater Seismic...
Porter Cable 7800 Drywall Sander- Head overheating/motor laboring
the drive shaft is probably going bad. If all the greese is gone then it will cause it to heat up. you can find parts and diagrams to fix it at www.deltaportercable.com. search for modle number 7800 under the parts section.
Mar 08, 2009 | Black & Decker Black Decker/ Porter Cable...
Drywall Logo
917 people viewed this question
Top Drywall Experts
ray gallant
John Donghia Jr.
John Donghia Jr.
Are you a Drywall Expert? Answer questions, earn points and help others
