I have a roper washing machine and it will fill with water and go through the wash cycle, but when it gets to the rinse cycle it stops and makes a humming noise, like it is stuck. If I tilt it back a few inches and let fall back to the floor it will start working again. It will then finish the remaining cycles. Before I start buying parts for it, does anyone have any suggestions for me. Thank You Doug
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
yes I have had same issue as your washer does. The problems you had is by replacing the motor it self. What happing was motor does not spin when it be came to rinse and spin that what make the motor to turn ON.
