I forgot my password need to reset factory settings
SOURCE: forgot password, does not have cd rom drive, need
Hi there, How to obtain Vista Recovery Media and/or use the Vista Recovery Partition on your computer to put it back to Factory Settings. There is no legal free Vista download available. They normally do that for a small $ cost. Also, ask them if you have a Recovery Partition on your Computer/Laptop to restore it to Factory settings. See if a Manual came with the computer, or go to the Manufacturer's website, email or phone them for info on how to do a Recovery. Normally, you would press F10 or F11 at Startup to commence the Recovery Process.. Another way I have seen on some models is to tap F8, and go to a list of Startup options, and start a Factory Standards Recovery from in there, by selecting the Repair computer option. Also ask them if it is possible to make Recovery Disk/s from the Recovery Partition in case of Hard Drive failure or System Crash. They will tell you how to do that. Each Computer Manufacturer has their own way of making Recovery Disk/s. If a clean install is required with a proper Vista DVD (not HP, Dell Recovery Disks): Go into your Bios/Setup, or Boot Menu, at startup, and change the Boot Order to make the DVD/CD drive 1st in the Boot Order, then reboot with the disk in the Drive. At startup/power on you should see at the bottom of the screen either F2 or DELETE, to go into Bios/Setup, or F12 for the Boot Menu http://support.microsoft.com/default.aspx/kb/918884 http://www.winsupersite.com/showcase/winvista_install_03.asp Windows Vista Installation Super Guide After installation > Go to your Laptop/Computer Manufacturer's website > Drivers and Downloads Section > Key in your Model number > Look for latest Vista Drivers for it > Download/install them. Save all Data, as it will be lost during a clean install. Post back if it is not working we will be happy to help you.
Contact your Computer Manufacturer and ask them to send you a set of Vista Recovery disk/s.
Or borrow a proper Microsoft Vista DVD(not Dell, HP, etc).
A proper Vista DVD contains all Vista versions.
The Product Key determines which Vista version gets installed.
There are 2 Vista disks: one for 32bit Operating System, and one for 64bit Operating System.
MS advice on doing clean install.
http://www.theeldergeekvista.com/vista_clean_installation.htm
A Tutorial on doing a clean install
Hope this helps.
Cheers!!!!
SOURCE: forgot password for tablet
Reset windows password not a problem any more nowadys.
The easiest way to reset a forgotten Windows password I ever use is to use Windows Password Reset ,just a few steps:
Step 1: Download and install Windows Password Reset
Step 2: Burn Windows Password Reset Std ISO file to CD/DVD
Step 3: Put in your newly created CD and remove your Windows Password.
Hope it can help you
SOURCE: i have a craig touch screen tablet and i forgot my dot password how do i reset it?
Unlock windows password,the easiest way I ever use is to adopt Windows Password Reset ,just a few steps:
For more details,go to: http://www.windowspasswordreset.net
SOURCE: want to reset to factory settings
This option will typically be under
Settings > Storage > Factory Reset
