Question about JVC HD-52Z575 52" Rear Projection HDTV-Ready Television
Hdmi input failure jvc hd-52z575 - JVC HD-52Z575 52" Rear Projection HDTV-Ready Television
6ya staff
SOURCE:
tvtek
Duke
  • 1284 Answers
SOURCE: jvc hdmi????
Changing the output to digital only affectts the audio output stream such as Dolby Digital or DTS audio. Try turning on the DVD player first then the television and see if then it sees the DVD player. Otherwise using the component outputs most will never see the difference n picture quality. Good luck.
Posted on Dec 12, 2007
Anonymous
SOURCE: JVC HD-52Z575
You both need to have a service center come out and reset the TV using the reset jig. This will correct the reverse image problem.
Posted on May 11, 2008
Anonymous
SOURCE: HDMI no longer working
JVC AV-48P575 HDMI reset procedure:
1. Unplug HDMI cable from tv.
2. Unplug the tv.
3. Remove the rear (low) back cover.
4. Find the 6 pins on the board of the HDMI module and shortcut the pins no.1 and no.2 using a jumper(i use an old hard drive jumper).That's the higher to pins if you can't see the number.
5. Put back the rear cover.
6. Plug the tv.
7. Turn on the tv.
8. Unplug the tv(without tunrning it off).
9. Remove the back cover.
10. Remove the jumper on the pins 1 and 2.
11. Put back the rear cover.
12. Plug the tv and you're done.
Posted on Nov 07, 2008
Anonymous
  • 60 Answers
SOURCE: JVC 52" HD-52Z575 shows double images of people and words
Its a convergence problem. You may want to check the site www.tvrepairkits.com. Every thing they said every description was right on. The best money I ever spent and the confidence you get from doing it yourself, Its a great feeling of achievement not to forget the live messenger support is instantaneous, friendly and informative if you need to fix your tv go to tvrepairkits.com I fixed a philips 60 inch tv in 45 minutes, The convergecne chips were bad thanks a million. You guys saved me 250.00 bucks. I'll be recommending you to everyone I know!
Posted on Aug 19, 2009
Paul
  • 381 Answers
SOURCE: Hi i have a JVC HD-ILA HD-52z575 50
Replace light engine.
Posted on Dec 15, 2009
JVC HD-52Z575 tv shows only a grey picture screen. I was watching a channel and tried to change channels and new channel won't come up, only grey screen.
JVC HD-52Z575 52" HD-ILA HDTV-ready rear-projection TV
www.amazon.com/JVC-HD-52Z575-HD...HDTV.../B...
Amazon.com, Inc.JVC HD-52Z575 52" HD-ILA HDTV-ready rear-projection TV ... The picture was artifacted and the color was good, but not great. ... From 5' some minor issues could be seen and the MPEG2 format did show its limitations, but at 10', it was a truly great experience! ... There is no true gray temperature, only high and low.
HOW TO FIX A JVC HD BIG SCREEN TV - YouTube
? 6:38
https://www.youtube.com/watch?v=r4v-xzUpQDM
Apr 11, 2012 - Uploaded by kyle dubb
Did your HD D.L.P. t.v. stop working? This movie clip will showyou step by step how to easily fix your big ...Missing: grey
JVC HD-52Z575 HD-ready rear-projection D-ILA monitor ...
Jan 10, 2016 | JVC Televison & Video
How do you reset the the lamp use time, after bulb replacement, on a JVC HD-52Z575 52inch Rear Projection HDTV
andycjavier,
See my tip at
http://www.fixya.com/TipsAndTricks/thanks.aspx?thid=8580883
Thanks for using FixYa and for the great rating.\
hardrocko
Mar 07, 2011 | JVC HD-52Z575 52" Rear Projection...
MY JVC52Z575 (D-ILA) HAS A REVERSED BLUE IMAGE OF ANY YELLOW IMAGE
I have the same blue shadow with reverse image on my JVC HD-52Z575 Did you see what the problem on yours finally was?
Feb 20, 2011 | JVC HD-52Z575 52" Rear Projection...
I need to replace the bulb and ballast in my jvc HD-52Z575 52 in rear projection hdtv-ready televvision. i need to know the part numbers and need to know where they are! I have no manual and would like to...
The parts diagram for the JVC HD-52Z575 is available here: https://www.searspartsdirect.com/model-number/HD-52Z575/1758/0333200.html . The lamp is part TS-CL110UAA. I don't see a separate ballast. If you look at the parts list for the cabinet, a Service manual is available.
I hope this helps.
Feb 20, 2018 | JVC HD-52Z575 52" Rear Projection...
Cant find HDMI Input in input screen
it has automatic signal detection,just like a computer with windows xp. if you plug in a jack,it tells you
Jul 17, 2009 | JVC HD-52Z575 52" Rear Projection...
HDMI interface issues
If you swapped directv receivers and the problem followed to a different tv then there is something wrong with the directv receiver. Need to run satellite setup again on this receiver to fix. repeat satellite setup is accessible through the setup submenu by pressing menu from the directv remote. look under satellite submenu once in setup
Dec 23, 2008 | JVC HD-52Z575 52" Rear Projection...
JVC HD-52Z575
Feb 17, 2008 | JVC HD-52Z575 52" Rear Projection...
JVC HD-52Z575 52" Rear Projection HDTV-Ready Television Logo
42 people viewed this question
Top JVC Televison & Video Experts
Todd Hill
Todd Hill
matt martin
matt martin
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
