Frigidaire ATF6000ES Front Load Washer Logo
A
Anonymous Posted on Jan 25, 2013
Error code eb2 - Frigidaire ATF6000ES Front Load Washer
1helpful
2answers
Code reader can't connect with vehicle computer.
Check for a blown fuse, some times the OB2 port shares the fuse like cigar lighter ,etc
press the helpful button
A29639
Wow, what a veteran. It is older than my 1964 bass. Your guitar was made at the Kalamazoo Plant, MI, USA in 1959, Production Number: 29639. In good condition it would be worth up to $5500, which I think is shamefully low.
Loc error code Frigidaire frontloader
From the frigidaire site.
Error code - Fault condition
E11 Fill time too long.
E13 Water leak in tub or air leak in air bell.
E14 Reed switch.
E21 Water not pumping out fast enough.
E23 Drain pump relay on control board failed.
E24 Drain pump relay on control board failed.
E31 Better models. Pressure sensor not communicating with control board.
E35 Better models. Pressure sensor indicates water overfill.
E41 Control board thinks the door switch is open.
E42 Door remains locked after cycle is completed.
E43 Control board problem.
E44 Control board problem.
E45 Control board problem.
E46 Control board problem.
E47 Board thinks the door PTC circuit is open in spin.
E48 Board thinks the door PTC circuit is closed.
E52 Bad signal from tacho generator.
E55 Motor overheating.
E56 High motor current.
E57 High current on inverter.
E58 High current on motor phase.
E59 No tacho signal for 3 seconds.
E5A High temperature on heat sink.
E5B High temperature on heat sink.
E5C High temperature on heat sink.
E5D Communication problem.
E5E Communication problem.
E5F Communication problem.
E67 Input voltage on microprocessor incorrect.
E75 Better models only. Water temperature sensor circuit.
E76 Better model only. NTC temperature for the cold water valve over the limits.
E95 Communication error.
EB1 Incoming power frequency out of limits.
EB2 Incoming line voltage above 130 VAC.
EB3 Incoming line voltage below 90 VAC.
EF1 Clogged drain pump.
EF2 Too much soap.
E62
Good Morning John, thank you for your post!
I see that your Frigidaire washer is continuously beeping and displaying error code E62. However, I show that the correct error code is EB2. Typically, EB2 indicates that the incoming line voltage is above 130VAC. Please verify that the power supply is correct. You may also disconnect the power to your washer for up to ten minutes by flipping the circuit breaker off and back on. This often clears most false error codes. If the error code does not clear, it would be advisable to contact a professional the since the main control board is possibly faulty.
My 1992 eb2 ford fairmont 5 litre goes to limp mode what are possible causes
Limp in mode has to deal with engine sensors and electrical power and grounds from the computer IF the basic engine is good such as compression, fuel pressure, charging system.
Washer turning on and off with beeps showes e62 error
Hello coollove60, thank you for your post!
I understand your washer shows error E62. However, it appears the correct error code is EB2. Typically, it indicates that the incoming line voltage is above 130VAC. Verify power supply is correct. If so, it would be advisable to contact a professional the since the main control board is possibly faulty.
E25
hello,
All error codes start with the letter "E". An error code of E11 will have the five indicator lights flash once and the Start indicator light flash once.
Some models of Frigidaire washers come with a digital readout display that informs the operator of the unit's function and any errors.
Error codes indicate that a problem has occurred and should be addressed. Different models of Frigidaire washers may vary in their fault displays.
Some washer models use flashing lights at the unit's start, door lock, wash, rinse, final spin and control indicators to display error codes.
If the five indica
tor lights flash more than nine times, this signals a letter in the error code. The letter "A" stands for 10 flashes, "B" for 11, "C" for 12, "D" for 13, "E" for 14 and "F" for 15 flashes. An error code of EB2 will have the five indicator lights flash or blink 11 times, and the Start indicator light blink twice
hope this help?
thanks.
Oct 23, 2010 • Dishwashers
E20 error message
replace the control panel or have it repaired,there is no e20 listed as a trouble code,so it needs to be replaced.
To clear latest stored error code:
Place the control into Diagnostic test Mode.
  • Turn the program knob clockwise 9 clicks from the Start Position. The control will signal the last error code.
  • Press and hold the Options and Pause Cancel buttons for 3 seconds. The code will be cleared.
  • Exit Diagnostic Mode to return the washer to normal operation.
E14 Reed switch.
EF2 Too much soap.
2helpful
Washing Machine starts, squirts water, then stops.
E5E  IS FOR  Communication problem. THERE IS 100 %WIRE SHORTING SOMEWHERE.PLEASE CHECK OUT.
ALSO OTHER ERRORS Error code - Fault condition
E14 Reed switch.
EF2 To much soap.
Top Frigidaire Washing Machines Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
