How do I disable the Beep function in a blomberg fridge? thanks.
SOURCE: Intermittent Beep
check door switch is operating and the light switches off. an easy way is to prize back the seal a bit with door closed and if light is still on you can see it
SOURCE: KOR-630A how do disable sound?
The only way to do this is to locate the piezo sounder on the control board & remove it. However, I do not recommend trying to do this yourself, unless you are trained & experienced in high voltage electronics, as there are INSTANTLY LETHAL voltages present inside, even if the unit is off & unplugged. The sounder is a black, cylindrical device with a small hole in the middle. It will be found on the printed circuit board behind the keypad, mounted either horizontally or vertically. There will be either 2 or 3 connections to the sounder.
SOURCE: How to disable the ATT function?
If you can remove the radio from your dash, unplugging its wiring harness for a minute should solve your problem - you will also lose your saved settings like preset stations and EQ. What type of vehicle is it in? In some cars it is easier to remove the radio than others. If it is proving too difficult, you could try disconnecting the battery for a minute and that should cause the radio to reset also.
SOURCE: disabling fridge lights
Inside the grill there are two light switches One for the freezer and one for the fridge. Pull one of the wires off each connector
SOURCE: Disable ABS without Beeping in Cabin.
If you don't care about the light being on, just unplug a speed sensor. Why do you want to disable it anyway?
