Coleman Hot Water on Demand Model #23000-700. When the heater was first turned on the igniter worked for 3-5 sec and has not since.The fuse was located and is in working order.The battery is fully charged but I'm not getting power to the pump, this has been checked by a multi meter
SOURCE: We done' use our coleman hot water on demand
I had a similar problem and was able to unscrew the screen at the end of the intake hose and manually move the pump propellor with a long nail which loosened it and it works fine now. I think it had seized with calcium deposit even though I had cleaned it as instructed.
SOURCE: Have three coleman hws same problem on last
It will probably be one of two issues. Either the waterflow sensor is not working correctly or the propane valve connected to to control knob is stuck shut. The water flow sensor is located on the side of the copper element (grey box) check that it spins easily. The propane valve is attached to the control knob by a long metal wire and should turn freely as you turn the control knob to warm
SOURCE: coleman hot water system has been charged for 3
Water heater will spark but will not ignite. Full Gas and Batt
has worked like a charm for two years
Need to restrict the water input so it does not flow through so fast
