Hi if your beko wma641w washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Also check all waste pipes are clear and inspect the pump I have included this video below.
At our website I am doing self diagnostic videos on these beko's as we speak so all tutorials will be in this link below
How to replace Beko Washing Machine Motor Carbon Brushes
you might find this test video helpful but only do it if you have checked the motor
I suggest to check your carbon brushes which are attached to your motor.When these wear down to a certain point (approx 10mm or less) the motor will not turn.You can find useful videos on the internet to show you how.Alternatively,It may be your belt at the back of your machine that has either slipped off or snapped.Best of luck to you,and let me know how you get on. Tks.
SOURCE: beko wahshing macnine wont spin
Check your exit hose spigot, it may be clogged. This is if your filter is all clean (ref manual). There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped. Click on 'thanks for trying' if not helped, your prob will be back for someone else to solve.
SOURCE: beko wma641w reset
hi
to reset these al you do is press and hold the start button for about 5 seconds then it should reset if not then you have a faulty pcb
regards
SOURCE: just change brushers on beko wma641w and now water
make sure you have a circut through the brushes
SOURCE: BEKO WMA641W washing machine not draining but pump
Are you sure the pump is working, or it the motor thats running? If the pump is truly working, there is a clog in pump or line. If the motor is working, but the pump is not, you will need to replace. You can usually buy a replacement pump for the washing machine for around $50. They are usually easy to install for a beginner DYI. Make sure you know the easiest way to remove washing machine housing to get at pump and motor. Unplug entire unit. Remove 2 hoses for pump and either screws or brackets to remove housing. BTW if the washing machine won't drain, you are going to have a bunch of water that gravity wants to dump out of machine. Bring pump to parts dealer for exact match.
SOURCE: child lock and spin/end lights on and stuck need to reset
Hard Reset - In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
* Unplug or turn the circuit breaker off for 30 seconds.
* Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
* Press the Pause/Cancel/Stop button twice to clear the "PF" in the display.
* Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
