Press the MENU button on the remote.
2. Press 3 to select the Screen option.
3. Press 4 to select the Adjust Projection TV option.
4. Press 4 to select the Advanced Convergence option (the
Advanced Convergence screen appears).
The green pattern is fixed. The red and blue patterns are adjusted to
the green pattern. The Red Convergence appears first by default.
5. Colored cross-hairs show the current adjustment position on the
grid. To move the cross-hairs to a different position, use the
CH+/- buttons on the remote to move the cross-hair highlight up
and down, and the VOL+/- buttons to move it right and left.
6. Use the arrow buttons to adjust the red pattern. Each press of
the arrow button makes a slight adjustment from the center of
the cross-hairs - you can press and hold the desired arrow
button to make a faster adjustment, and then make fine
adjustments with single presses of the arrow button.
7. Press the INFO button to switch to Blue convergence and follow
the steps above to adjust the blue pattern.
8. Press OK to exit. You will be asked if you want to save the
adjustments
Yes Saves adjustments.
No Returns to the Advanced Convergence screen allowing
further adjustments.
Clear Exits screen without making any changes
Note: Before you use the advanced convergence feature, you must
complete the previous steps to align the tubes
The List & Labels part of the setup lets you edit your channel list and choose or create a
personal six-character label for each channel.
Note: Changing List and Labels can be time consuming. You can change these at a later time by accessing the
Setup menu.
1. Press the left or right arrow to scroll through the available channels and choose the
channel you want to edit.
2. Press the down arrow to highlight the In channel list option. Press the left or right arrow
button to add (the box is checked) or remove (the box is unchecked) the channel from the
list.
3. Press the down arrow to highlight the Channel label option. Press the left or right arrow
button to scroll through the available list of 25 most common labels. The last option in
the list allows you to create your own six-character label for the channel (the first letter of
the label is highlighted).
4. Press the 1 or 2 number button to change the first letter of the label.
5. Press the right arrow to highlight the second letter, then press the 1 or 2 number button
to change the second letter, etc...
6. When you are finished creating your label, press OK. For model D34W20, your TV tunes to
the last channel available in your channel list. For models D40W20 and D52W20 only, the
Auto Convergence menu appears next.
Auto Convergence (for models D40W20 and D52W20 only)
Your TV's picture tubes might have been disturbed during delivery or after you moved the TV,
causing the color in your TV to be out of alignment. The colors adjust by starting auto
convergence.
1. Press OK to begin auto convergence.
2. When the auto convergence is complete, the Red center convergence menu appears. The
cross in the middle of the screen should be yellow. If it is not, use the arrow buttons to
move the red cross to overlap the green cross. Press OK when adjustments are complete.
3. The Blue center convergence menu appears with a cyan cross in the middle of the screen. If
it is not, use the arrow buttons to move the blue cross to overlap the green cross. Press OK
(the TV tunes to the last available channel in the channel list).
Ok
Problem with Hitachi 51F500 51 in. Rear Projection HDTV-Ready Television
i want to learn how to do convergence on my tv its a hitachi rear projection i have problums with colors not aligning,could you lead me in the right direction ps: i don't have the remote so i
can't magic focus
Posted by ejaparks on Mar 03, 2011
www.graysoncollinapplianceandac.comResidential/ Commercial, all brands Friendly, knowledgable technicians!
Get $75 of Advertising
www.Google.com/AdWordsPromote Your Business On Google. Claim Your $75 Coupon Now!
Solutions (1)
Your convergence has failed and needs to be repaired. Once quick test is to goto your convergence menu and see if you can adjust red and blue. If not its has failed and needs to be fixed. You can call in a repair shop or you can get the parts and instructions from www.TvRepairKits.com and do the repair yourself. Its a fairly easy DIY fix.
Here is an example photo....
