Dirt Devil Vision Turbo W/Bonus Upright Vacuum Vacuum Logo
Posted on Jan 24, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My dirt devil has no main suction
I have cleaned out the hose and replaced the belt.
Anonymous
Level 3:
Genius:
  • Master 1,669 Answers
  • Posted on Jan 24, 2013
Anonymous
Master
Level 3:
Genius:
Answers
1669
Questions
Helped
428184
Points
5349
Is the motor turning? If so the fan unit is disconnected from the motor shaft,
Jerry Kramer
Level 3:
  • Dirt Devil Master 3,933 Answers
Jerry Kramer
Dirt Devil Master
Level 3:
Answers
3933
Questions
Helped
882205
Points
12076
You need to go a bit deeper in the unit to get what is clogged. it is most likely clogged on the inside of the unit. Take off the back and remove the inner workings following the path of the suction. Not hard to do just sucks.
Dirt Devil Total Pet hose not suctioning
The hose must be blocked. Push a broom handle down it.
My dirt devil cyclonic upright has suction on bottom but not in cleaning wand
Take the hose off where it goes in to the vacuum and see if there is something lodged in the opening where the hose fits in to.
Got a dirt devil upright I've cleaned out the Short hose extension hose also cleaned under bottom plate checked belt looks good don't see no holes or cuts in hoses no cracks in bagless container
Hello, Im assuming that your unit has no suction. If this is the case, it is still plugged. Run a stiff wire through all the hoses, starting at the on behind the bristle brush. Make sure all the bagless filters are completely cleaned.
My Dirt Devil en vision hose has good suction but zero suction at the bottom. Clean filter,no clogs.i know replacing the broken belt will make the brush turn. Will it enable suction also?
If you have fixed the suction at the bottom, a new tight belt is important when vacuuming carpeted floors. Belts lose elasticity from being stretched which is why they need replaced frequently.
How to fix dirt devil featherlite carpet cleaner loss of suction?
Hello! Below are general trouble shooting steps for your Dirt Devil vacuum to restore suction.
1. Check the hoses for clogs.
2. Clean and replace your filters if needed.
3. Check that your brushes are still spinning, if not, replace your belt with the recommended belt for your vacuum.
Hope this helps!
4helpful
I have a dirt devil featherlite bagless vacuum; model #088600. It has suction through the hose but not through the floor mode. I think there is a blockage in the hose area but cannot seem to take it apart...
there are 3 screws 2 on the left side behind the hose and 1 on the right back by the wheel.that will take the cover off.if you need to get into the bottom there is a screw on the bottom plate in the area where it looks like the belt travels.is the brush roller turning if not then your belt is probably broke.before you replace the belt clean off the motor shaft and get the old rubber off it otherwise the new belt won't last long.please leave feedback .be sure to clean your filter inside the dirt cup
No Wind Coming Out of Dirt Devil
The suction hole will never have wind coming out of it, it is for suction. To switch from floor to hose, turn the control knob labeled floor / hose.
2answers
No suction
Check the main filter cone - if it has a rip in it, then there won't be any suction in it, also clean it gently with a paint brush to get all of the dust out and check the back of the upright after the bin is taken out as sometimes there is dirt clogged at the back. Check the front of the sole plate i.e. where the roller brush is and check the dust channel behind this as it can get clogged. Due to the nature of this vacuum with the hose being located at the front of the floor head dirt can be trapped but most of all its the paper pleated cone filter that needs a good brushing. Hope that helps.
2answers
Dirt Devil Vision bagless not working
Check the dirt cup filter. remove the dirt cup and check for proper suction. if you have good suction, check your belt
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
Top Dirt Devil Vacuums Experts
Mike Cairns
Mike Cairns
Paul Bade
NOEL
NOEL
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
