Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model Logo
Mark Posted on Jan 24, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My 18 hp cub cadet deck belt continually jumps off pulley
Anonymous
Level 3:
Genius:
  • Master 1,669 Answers
  • Posted on Jan 24, 2013
Anonymous
Master
Level 3:
Genius:
Answers
1669
Questions
Helped
428182
Points
5349
There are MANY pulleys on that deck. Which pulley are you talking about?
Cub cadet m60-kh the PTO belt keeps jumping off
https://www.partstree.com/parts/cub-cadet/mowers-zero-turn-lawn-mower/m60-kh-53ab5bdx750-cub-cadet-commercial-tank-zero-turn-mower-27-hp-kohler/fabricated-deck-spindle-assembly/
Likely the deck idler pulley is loose or bearings are shot. The pulley should not wobble and the flat side of the belt should ride square against the pulley face (the pulley should be reasonably perpendicular to the deck). If not, the idler arm pivot is loose or the pivot bolt and arm are shot. Check proper tension is applied by idler pulley torsion spring (the belt is not loose).
c1-rh14230rqgibnrzrzz3yshgm-3-5.png Comment here and Ill assist further if need be.
I need to know how to install drive belt on cub cadet that has hydro drive with diagram
That will depend on the model of your mower. Generally you have to remove the deck and deck belts. The drive belt usually goes from the engine pulley to the transaxle pulley. There may be a tensioner pulley as well that keeps the belt tight.
2answers
How to replace mower belt for ZTR cub cadet mower
Changing the Blade Drive Belts:
a.Set the parking brake. Remove ignition key and both spark plug caps.
b.Unscrew the wing nuts from the deck covers and remove both covers.
c.Using a 3/8" socket breaker bar or socket ratchet insert the drive end into the 3/8" square opening in the lower idler arm assembly and push the idler arm counterclockwise. While holding the idler arm back, loosen the blade drive belt from the pulley and slide the belt away from the pulley.
d.Remove tension of the PTO belt by moving the belt tensioning rod. Loosen the belt retaining bolt.
e.Pull the tensioner pulley away from the belt and remove the PTO belt then remove the blade drive belt.
f.Reverse the process to install the belt.
2answers
How to replace belt model 2155 cub cadet engine pulley to deck?
Download the owners manual from Cub Cadet using model number 13A-244G100.
Customer Service Cub Cadet
Diagram for drive belt pulleys for cub cadet 1045
Round the two outer pulleys on the deck. Round the the outer pulley in middle deck, round idle pulley inside, next pulley in center of deck to drive pulley
May 03, 2012 • Garden
3answers
Cub cadet belt keeps coming off the deck
Link to see video of the Fix for cubcadet deck belt coming off can be viewed here: http://www.youtube.com/watch?v=Pd4nYovcnvY
1helpful
Was mowing-blades just quit turning-pto will not engage
Belt has broken, or jumped off the pulley, or jumped off the belt tensioner. Look at your deck and go from there. You may have to remove your deck to get to the belts under there cvers but you will see your problem.
982 cub cadet 3 blade w/ idler pulley deck belt diagram
hi there pauly 46 here
here is web site for streetsign cub cadet 982 46 " deck with 3 blades
http://www.partstree.com/parts/?lc=cub_cadet&mn=336+46%22+Mower+Super+Garden+Tractor&dn=0057000002
this shows deck belt routing
and here is website area for 982 parts break down for model 982 cub cadet
http://www.partstree.com/parts/?lc=cub_cadet&mn=982
take a look cheers hope it helps
pauly46
Top Craftsman Garden Experts
john h
Jay Finke
Jay Finke
Sean Wright
Sean Wright
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
