Toshiba 46xf355db upon start up there is a fuzy picture and lines
Toshiba 46xf355db upon start up there is a fuzy picture as if the screen cant hold all the lines together, after about 10 minutes the picture is fine or if you turn the tv on and off a few times it fixes the problem quicker. However once it is working there is still a couple of vertical lines on either side, after a longer period of time the lines on the right side vanish and everything is ok bar one line on the left. How can I tell if it is the screen thats at fault, inverter board, pcb, main board? many thanks
  • 3,388 Answers
I believe that tv is about 10 years old. The best solution and probably most cost effective is to replace it.
Posted on May 17, 2017
5 Suggested Answers
sanjin
sanjin becirbegovic
  • 56 Answers
SOURCE: 42' plasma daewoo tv with vertical color lines.
the way how you described it looks like the screen is cracked but problem can also be in VPB (video process board).But without the model name its very hard to tell you more
Posted on Feb 19, 2008
Anonymous
SOURCE: Vertical green lines on screen
IF THE LINES ARE ON LEFT SIDE ITS THE LEFT BUFFER BOARD AND VICE VERSA THEY ARE ON THE BOTTOM OF YOUR TV HOPE THIS HELPS YOU OUT
Posted on Apr 03, 2008
Anonymous
  • 10 Answers
SOURCE: red vertical line down right side of the screen
hi
I think your TV have a trouble inside lcd panel
the controller board contains driver IC. Deffective driver IC can cause of line display.
Three reasons why one vertical line accross screen can happen in LCD;
1.The missing signal from the controller IC to
LCD driver.
2. LCD driver IC itself defective
3. Dry contact in the tape carrier package.
Use masking or electrical tape to mark it where the line was located. press it if the line back to normal but when release your hand came back i think it was intermittent. Open the LCD panel
Use robber
Place the rubber on the top of TCP
Gently close back the top casing
Good luck...
Posted on Aug 21, 2009
Anonymous
SOURCE: Vertical red line on Toshiba REGZA 52HL167 tv.
I have this same problem with my 52 inch toshiba regza , The repair shop has said the cost of repair is as much as it is to replace the TV. I am past the one year warranty, but less than 2 year ownership, so Toshiba won't fix the known issue. Solution is don't buy a Toshiba
Posted on Feb 05, 2010
Anonymous
SOURCE: Vertical colored lines on left half of screen.
I had this problem on a 37" Viewsonic LCD. Pulled it apart and through a process of elimination, I traced the problem back to a small board with several flat white ribbon cables coming out of it. The board was near the top center of the screen and under a ton of other equipment requiring almost a total disassembly.
This small board was clean but I noticed one of the rubber standoffs had slipped down and was making contact with one of the outputs running to the LCD. It also happened to be the output running to the section of the screen with the problem.
I postulated that the sticky glue on the rubber standoff may have just enough conductivity to cause a problem. Moved it so that it was no longer touching anything electrical and then reassembled the TV.
Afterwards, I turned it on and was pleased to see the problem has gone away! If you're having the vertical line problem, then maybe this could be your problem too, especially if you have a Viewsonic since it could be a manufacturing defect.
Posted on Mar 22, 2010
Toshiba Satellite L505D-S5983 black screen
Hold the power button down until the unit shuts off, wait 10 seconds then turn it on again.
Upon restarting, make sure to choose Start Normally if the startup failure menu comes up.
Apr 13, 2014 | Toshiba Satellite Computers & Internet
Nothing but multi colered lines verticly on the screen
Try this:
Turn it off.
Disconnect power cord and any other device attached to it.
Take battery out.
Without anything attached. Hold down the power button for 10-15 seconds.
Connect the power cord only.
Hold down F2 (while it's off)
Turn it on while holding down F2.
Let go of F2 when something comes out of the screen.
If multi colored lines still appears.
You have either defective LCD(screen) or video card.
Jan 30, 2010 | Toshiba Tecra M2 Notebook
Red fuzy screen
You had not fixed all connector properly.
Jan 23, 2010 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Black lines in tv
Most likely there are electrolytic capacitors in the power supply, video path, and scan amplifiers that are starting to fail from age. This is common in many of these sets. In consideration of the age of the set, this may not be worth having it serviced.
Jerry G.
Sep 24, 2009 | Toshiba 51H93 51" Rear Projection HDTV
I am repairing my sister TV {Toshiba TN61X81}. The original was no picture and with sound. Upon troubleshooting the vertical deflection, ihad move the screen control for all 3 crts to see the horinzontal...
The easiest way I have found to set the screen controls is to tune into an old black and white show, turn the green up until you see retrace then slowly turn it down until it just dissapears then adjust the blue and red for a true black and white picture.
Sep 08, 2009 | Toshiba TN61X81 61" Rear Projection...
Toshiba Rear Projection TV Picture Problems
The convergence circuits need to be replaced Sometimes it is just the matter of 4 capacitors and an IC but often than not ythe whole board has to be replaced.
Sep 02, 2009 | Toshiba 57HX81 57" Rear Projection...
I have a Sony Grand wega im getting fuzy purple diagnol lines
Try changing the component cable to your Video 6 and see if you have the same problem. I tried this and figured out that the set top box from Verizon component connections may be bad. I also tried changing to a different set of component cables to troubleshoot. I figure its the box not my TV.
Mar 15, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
32 inch tv/dvd combo, has sound but no picture. Upon turning it on we get a momentary flash of a picture, and that all. The screen goes blank.
it sounds to me your tube has gone, there cheap to replace just pop down to your local tv shop they should be able to get hold of one for you.
hope this helps...
Mar 10, 2009 | Toshiba Televison & Video
Televison & Video Logo
82 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
