SOURCE: ESCORT PASSPORT 8500 WILL NOT
you might as well check if you can turn on using only the battery. If it wont, then try to push the power button for 8 secs after you remove the battery and power cord. Then reinsert power cord, and turn it on. If it still no good, then call escort because this issue is something to do with the system board inside of it. It does not react to the situation wherein you have plug the working power cord and a working battery.
SOURCE: escort passport 8500 error 13
This is an error message which indicates a specific internal component failure. Escort will have to fix your 8500.
SOURCE: Escort, passport 8500
Hold all three buttons down at the same time to reset the device. If this doesn't work it probably needs to be sent back for repair/reflash. Jack
