SOURCE: Will ethernet USB cable work with Archos 101 as it
Archos support is correct, if it doesn't use a simple interface like a hard drive or mouse/keyboard, then it won't work on the Archos 101.
Manufacturers aren't releasing Android drivers yet for the most part, so I wouldn't expect an ethernet to USB cable to work any time soon, sorry!
SOURCE: Ho to update firmware for
Let me just take a wild guess as I don't have a tablet pc but Archos.com via usb might help or whatever it is you connect to your desktop connection.
SOURCE: I reformat my archos 101
If your ARCHOS does not respond correctly or does not start properly, you can try to remedy this situation with a system recovery. Be very careful with this as there are options to erase all the data on your device.
20.3.1. To enter into the Recovery screen - Turn off the device and wait 10 seconds.
- Press and hold the volume + button while powering on the device.
- Keep the volume + pressed until the Recovery mode starts (white screen).
- To move from one Go to this web page to see the latest on-line version of this manual. Go to this web page to see the latest on-line version of this manual. Go to this web page to see the latest on-line version of this manual. Go to this web page to see the latest on-line version of this manual.option to another, use the volume buttons. To select an option, press the ON/OFF button. Go to this web page to see the latest on-line version of this manual.
20.3.2. Recovery mode options
No: Cancels the system recovery.
Update firmware: Allows you to connect your device to a computer in order to copy the latest .AOS file (operating system) to your device and then install it.
Repair System: Attempts to repair the file structure on the internal memory. This does not erase any data.
No: Return to main recovery screen.
Force Touchscreen Calibration: Select this, set your device down, start the calibration, and don't touch it. It will re-calibrate the screen. After the calibration is complete, select No to leave the recovery screen.
Check Disk: Check and repair the system partition if damaged.
Start USB MSC: Allows you to connect your device to a PC to access the internal memory.
Format System: Formats the internal memory. All data (music, photos, videos, etc.), applications and settings are erased.
HOPE IT HELPS AND GOD BLESS!!!
SOURCE: please send me necessary
You download the updates from within the tablets OS.
Comment if you need additional assistance.
