Want to know which processors are compatible with above motherboard
Hello here is the cpu list:
http://support.asus.com/cpusupport/list.aspx?SLanguage=en&p=1&s=22&m=P5KPL-AM&os=17&hashedid=xs6iinKxu0y5agcg
Good luck
SOURCE: Processor compatibility- ASUS P5S800-VM
Asus P5S800-VM do NOT support Core 2 Duo: http://support.asus.com/cpusupport/cpusupport.aspx?SLanguage=en-us&model=P5S800-VM
SOURCE: mx45 u2-cn motherboard
you meen MX46 U2-CN this board does not support fsb533 only 400MHz will works on it.
Your board supports P4 CPU with 400Mhz bus speed. You can use any P4 CPU with 400MHz such as 2.4GHz/512/400. I think you can go as high as 2.8GHz.
Good Luck!
SOURCE: Asus P5GZ-mx compatible graphics cards
Basically, any graphics card is capable of being compatible with this motherboard. I had some difficulties for a while until I figured out you have to MANUALLY set it to use your PCIE 2.0 GPU output.
How to do this is to set your jumpers to external output only. First thing you'll want to do is update the BIOS on the motherboard (Which you can do by getting "Asus-Update". Find it on google, easy to use, just make sure your computer doesn't crash during the BIOS flashing.
Afterwards, set the jumpers to use your PCIE-2.0 slot. Took me a little while to figure this out, and it's a little hard to explain.
Above your PCIE-2.0 slot there are 5 little blue 'plastic-like' things. Those are your jumpers. Take them out and insert them HORIZONTALLY as such:
Basically, make sure the jumper things are connecting the little drawing there. They HAVE to be horizontally inserted, otherwise this WILL NOT WORK. Just plug in your monitor to the graphics card's output, and you're good to go. Hopefully it works for you.
SOURCE: PROCESSOR, MOTHERBOARD AND POWER
Some motherboards with 8-pin and 24-pin power connectors support 4-pin and 20- pin connectors, like my Gigabyte GA-MA790GPT-UD3H AM3 AMD 790GX.
